When I took my IC off last time to install my pitch mount, I had a heck of a time getting it back on correctly. I think I put a very slight tear in the one hose on the bottom (turbo outlet/IC inlet), but it is on the other side of the hose clamp and I doubt it is causing an issue currently. I plan on taking the IC off again to put a down pipe on, and I was thinking that I should just pick up a new set of the two hoses and some better clamps to be safe.
I can't even find a 'kit' for IC tubing for the newer STi's - just one for older ones or WRXs.
Can I just buy a generic silicon coupler and a right angle piece that I can trim to size? I also do not know the ID of either of the tubes required.
Any suggestions?
