1 - 20 of 286 Posts
Gigs STi wagon
Youtube - https://www.youtube.com/channel/UCR9dFmgscOogL5zOydUWXwA/feed
Instagram - https://instagram.com/jn_garage/
Website - https://jngarage.com/
2006 Legacy GT Limited Wagon
Spring 2017 Plans
Safe tune and Spec B Billstein struts
Engine
Stock
Transmission
Stock 5at
Suspension
Stock , But suspect it was replaced
Interior
VicTsing FM Transmitter, Bluetooth FM Transmitter Radio Adapter Car Kit
Exterior
Stock
Wheels / Tire
Winter - Stock wheels with 215/45/R17 Hankook I Cept Evo 2 snow tires
Summer - Looking for 17x8 or 17x7.5 Rays TE37 / CE28n with 225/45/R17 Continental DW
2003 Wrx wagon
2003 Subaru Wrx Wagon
Exterior modifications
Sedan widebody conversion
Prodrive bumper
Engine
S204 EJ207
3 Port EBCS
Tomikoa Downpipe
Greddy TI-C catback
Koyo Radiator
Samco hose kit
Transmission and Driveline
Group N Bushings
Exedy twin plate clutch
Version 7 R180 suretrac LSD
Version 7 Type RA STi Transmission
Ratios
3.636
2.375
1.761
1.346
1.062
0.842
Brakes and Suspension
Version 7 STi Brembos
Brembo Rotors
Project Mu NS400 / HC800 pads
Prova replica brake ducts
21mm Front and Rear STi S204/ RA-R Sway bars
STi Pink trailing arms
Version 7 STi lateral links
Wheels and Tire
Mach V Awesome 17x9 +42
245/40/R17 Hankook RS3
Videos and stuff
Æternum
Joey?
Miss my wagon :(
Sent from my SAMSUNG-SM-G890A using Tapatalk
Joey?
Miss my wagon :(
Yes sir !
That is why I can't sell this car , Too many memories and I would cry watching someone else modify it.
Discussion Starter #7
Very nice! Auburn Hills? I work in Rochester. Surprised I haven't seen this bugeye on the road around here yet.
That's because it has not been driven since October haha.
Were doing a meetup tomorrow at Griffin Claw Brewing @2pm if you are bored !
Car won't drive for another few weeks as its in paint now.
I Drink & I Know Things
Ah, I see. That makes sense. Haven't been there. I would, but I think my wife has plans for me tomorrow. lol
If that changes then I'll see if I can swing it.
Discussion Starter #10
Awesome man! I just skimmed the track video. Looks like it really gets up and moves!! Nice work man. I'd love to be able to track mine..
It moves but the driver is still years behind in driving talent !
The car is hitting 92-94% IDC so next month I will be adding in larger injectors and a FPR as well. Probably can get some more power out of it too as its really conservatively tuned now.
Nerdus Socialis
Haha you looked pretty solid in the video!
Sounds like some good changes then
Discussion Starter #12
The 5x114 hub changes and actually going to a track pad over a street pad will be more noticeable. Pad knockback with the 5x100 hubs is a little scary at over 100mph
Æternum
Does the S204 engine have any different running gear compared to the typical spec C EJ207?
Discussion Starter #14
VF42 turbo
hand balanced and built bottom end
Comes with a hard silicone inlet hose from the factory
balanced flywheel and clutch assembly
Rumored to be different cams
way more aggressive ecu tune
a bunch of little things that add up to make an impact , This engine also only had 11k miles when I first got it.
Æternum
The hand built bottom end probably helps with the poor PTW and general loose tolerance issues plaguing the EJ motor.
Discussion Starter #16
The EJ207s don't really seem to suffer from that same fate and are built pretty tight from the factory from what I have seen. This one is a little looser due to the abuse it was expected to take. I run a 50 weight oil in it usually as I found 40 weight did not hold up as well on the track.
Æternum
Certainly the smaller bore helps with the poor PTW clearance concerns, but even the EJ205 had poorly controlled tolerances. I'm sure the assembly processes are far out of date
1 - 20 of 286 Posts
