I've recently picked up a v8 ej207 short block with 130k on it, it also came with the Avcs cams, pulleys and the 05 sti Ecu.
I'm going to use my B4 heads and get them overhauled with new valves, springs, retainers and guides.
I want to use second hand parts where possible, this is going to be my daily driver, also contemplating going e85
Question:
- should I wire in the sti Ecu so I can use the avcs cams and pulleys I got with the short block. Or just get get new non avcs cams and run the standard Ecu.
- should I just use a second hand sti tmic or go second hand fmic
- I've got some v8 sti twin scroll heads and sump the suit, what kind of turbo would be suited to the standard v8 sti avcs cams if I go that way. Or what cams and turbo recommendations do you guys have for me..
I really want this thing to be pulling hard at high revs.
Here's my rough shopping list
Bit Front mount or better Tmic with hood scoop
Water pump
Oil pickup
Up pipe
Turbo, twin scroll
Down pipe
E85
Injectors
Aos catch can
Silicone inlet
Wide band o2 sensor
Wastegate, external?
Valves
Springs
Retainers
Guides
Heads serviced
Bov
Pistons?
Shifter bushings
Engine mounts
Transmission mounts
Rotating assembly balanced
Fuel pump
Fuel regulator
3 port boost solonoid
Head studs
Fuel filter
Oil cooler
Any support and suggestions are much appreciated
Sent from my iPad using Tapatalk Pro
