1 - 17 of 17 Posts
Every time I gas up my check engine light comes on. I have cleaned the gas cap. When I remove the negative for 5min it will clear. I don't want to have to disconnect my battery every time I fill up. I hate setting my clocks. Lol
Æternum
What's the code?
Are you able to fill the tank?
You should not be randomly clearing DTC codes.
Discussion Starter · #6 ·
I can fill the tank. I plan on getting a code reader tonight if i have time. It has happen every time i have filled up and about 3-5 miles into driving. I have filled up 3 times sense buying it.
Super Moderator
That's the rear o2 sensor if I'm not mistaken. It's either shorted or dead.
Æternum
Exactly what are the mods on the car?
It is the rear O2. Either the car has the wrong map, the sensor's wiring is faulty, the sensor is malfunctioning, or the sensor is missing. More than one is also possible.
Æternum
Intake and exhaust is the only thing I think. My next days off I plan on trying to get to the senor to take a look.
Exactly what parts of the exhaust?
1 - 17 of 17 Posts
