221 - 240 of 278 Posts
Discussion Starter #238
Since I can't edit my original post here is my Updated OP:
Mostly GD WRX & STi parts but some 04 FXT, 05 LGT & 04 RS parts as well.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
Links to albums of individual pictures of each part are located beside each group
04 FXT Pics: • 6 Disc $25 (one speaker channel doesn't work)
• ACT 6 puck & pressure plate $100
• ACT lightweight flywheel $100
• Manual Driveshaft $50
• Control Arms $50
• Sway Bars $25 each
• Front sway bar mounts $10
• Rear sway bar mounts $10
• Center differential $200
• Front differential $150
• 5 speed transmission case $100
05 LGT Pics: • Intake manifold $50
• Engine harness $50
• Side feed TGVs $80
• Side feed fuel lines $50
• Gauges auto $75
• ECU auto #22611AJ18B $100
• MAF #22680AA31A $35
• BPV hose $5
• Airbox lid $5
• Intake pressure sensor #22012AA160 $5
• Boost solenoid controller $25
04 Impreza RS
• Shortblock $250
• SOHC Complete Heads $200
• Plastic Intake Manifold $125
• Throttle Body $75
• Fuel Lines $40
• Engine Harness $75
• Crankshaft Pulley $30
• Injectors $40
• Air Assist Injector $35
• Fuel Pressure Regulator $35
• Ignition coil $20
• Coil packs $40 set
• Fuel Rail Covers $10 each
• Timing Covers $10 each
GD WRX & STi Parts
Engine & Drivetrain Pics: • JDM EJ20x stroked 2.1 shortblock (fresh rebuild <2k miles) $2000
• JDM EJ20x Dual AVCS cylinder heads (need cleaned) $400
• 06 STi Camshafts $250
• 06 STi 5x114 Knuckles $100 each (34k miles)
• 06 STi rear axles $100 each (34k miles)
• 06 WRX front axles $75 each
• ARP head studs $75 complete set
• Cam Gears: #13320AA000, #13320AA001, #13321AA001, #13322AA000, #13322AA001 & #13323AA001 $100 each
• EJ20 valve covers $40 set
• STi front axle without outer CV $30
• STi clutch master $40
• STi side feed fuel rails with line $50 set
• STi passenger side feed fuel rail with line $25
• Side feed TGVs $80 set
• Purge valve $10
• Purge valve solenoid $25
• STi proportioning valve $20
• Boost solenoid controller bracket $5
• Radiator mounts $10 set
• Power steering reservoir $20
• Power steering reservoir bracket #34633FE001 $5
• 04 WRX steering column with ignition & key $75
• 04 STi steering column with ignition, key $100
• 06 STi steering column with ignition, key $100
• Pull type clutch fork pin (5 or 6 speed) $20
• Transmission mount $20
• AC compressor $80 #73110AE021
• AC condenser $40
• STi passenger radiator fan $25
• Radiator coolant hard line $10
• Manifold coolant hard line $10
• Water temperature sensor $10
• Oil dipstick $10
• TMIC hard lines $10
• Oil cap $5
• Oil cap with fill neck $10
• 02-05 WRX cruise control actuator module $20
• Hood prop $5 (2 available)
• Battery tray $5
• Turbo uppipe bracket $5
• Pitch Stop Mount $10
• Left, Right & Center Outer Timing Covers $15 each
• Front O2 sensor plastic cover $5
• AC Lines $25+
Suspension & Brakes Pics: • Front sway bar mounts $10
• WRX STi ABS module #27534FE270 $40
• ABS Sensors: #27540AE000, #27540AE001, #27540AE010, #27540FE040 & #27540FE050 $20 each
• 5x114 rotors were turned and never used $50
Exterior Pics: • BBS center cap $20
• Driver rear exterior door handle PSM $20
• Wiper arms $30
• Passenger mirror CGM $25
• Driver mirror no cover black $25
• Passenger mirror no cover black $25
• Gas lid PSM $10
• Exterior B pillar molding $15 each
• GD Doors $150 each
Interior Pics: https://imgur.com/a/G7vOkeh
• Center rear view mirror sun visor $10
• Visor clips $5 set
• Interior mirror cover right #94251FE000 $5
• Interior upper B pillar trim $10 each
• Interior lower B pillar trim $10 each
• Interior C pillar trim $10 each
• Rear seat trim $10 each
• Trunk latch trim $10
• Door kick molding trim $10 each
• Driver center console side cover $10
• Rear heat vents $10
• Seat belts $40 each
• Seat belt buckles $10 each
• Trunk release cable $10
• Gas lid release cable $10
• WRX trunk hinges $20
• WRX torsion bars $20
• Weatherstripping: Doors, hood and trunk available $5 each
• Fuel pump cover $5
• Jack $5
• Trunk left and right liners $25
• Rear dash $40
• Bugeye door cards $50
Electronics Pics: https://imgur.com/a/QuPpVtK
• 05-07 mirror switch $10
• 02-04 mirror switch $10
• Hazard switch $10
• Engine bay fuse box $25
• Rear view mirror wire cover $5
• Map light $20
• Dome light $20
• 04 STi ignition, key $40
• 06 STi ignition, key $40
• Headlight/blinker switch $25
• Wiper switch $25
• OEM horns $5 (2 available)
• ECU cover $10
• Wiper motor $40
• Positive battery terminal cable $5
• 04/05 WRX fuel tank wiring $20
• DRL module #84067FE060 $10
• DRL module #84067fe000 $10
• 04/05 control unit air bag #98221FE110 $40 (2 available)
• 06/07 control unit air bag #98221FE220 $40
• WRX STI left front air bag sensor #98231FE070 $10 (2 available)
• WRX STI right front air bag sensor #98231FE060 $10 (2 available)
• WRX STI left side airbag sensor #98235FE150 $10 (2 available)
• WRX STI right side airbag sensor #98235FE140 $10 (2 available)
• WRX STI left side airbag sensor #98231FE010 $10
• WRX STI right side airbag sensor #98231FE000 $10
• Airbag harness $25
• WRX STI G Sensor ABS #27540FA022 $10
• WRX STI G Sensor ABS #27540FE090 $10
• Fuel injector resistor module #684227 $10 (2 available)
• Door ajar sensors $20 set of 4 (2 sets available)
• 04/05 WRX STi keyless entry module #88035FE140 $20
• 04/05 WRX STi keyless entry module #88035FE141 $20
• 06/07 WRX STi keyless entry module #88035FE190 $20
• 04/05 WRX STi integrated control module #88281FE160 $20
• 06/07 WRX STi integrated control module #88281FE340 $20
• WRX STI clarion antenna amplifier assembly #86327FE090 $20
Discussion Starter #239
• ACT 6 puck & pressure plate $75
• ACT lightweight flywheel $75
• Control Arms $25 each
• Gauges auto $75
• BPV hose $5
• Airbox lid $5
04 Impreza RS
• Shortblock $250
• Throttle Body $75
• Fuel Lines $40
• Injectors $40
• Plug wires $40 set
GD WRX & STi Parts
Engine & Drivetrain Pics: • 06 STi 5x114 Knuckles $100 each (34k miles)
• Purge valve $10
• AC condenser $40
• Oil dipstick $10
• Oil cap $5
• Battery tray $5
• Pitch Stop $10
• AC Lines $25+
• Wiper arms $30
• Gas lid PSM $10
• Jack $5
• Rear dash $40
• Hazard switch $10
• Map light $20
• Dome light $20
• 04 WRX ignition & key $40
• 04 STi ignition & key $40
• 06 STi ignition & key $40
• Wiper switch $25
• ECU cover $10
• Wiper motor $40
