Mostly GD WRX & STi parts but some 04 FXT, 05 LGT & 04 RS.
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
04 FXT
Intake Manifold $100
Rear Crossmember $100
Rear Sway Bar $25
Front Sway Bar Mounts $10
Front Differential $150
05 LGT 111k Pics: Crankshaft $200
Pistons $25 each
Intake Camshafts $100
Metal AVCS Intake Cam Gears $75 #13320AA000 RH & #13322AA000 LH
Timing Covers $15
BPV Hose $10
OEM Inlet $20
Coil Packs #FK0186 $35 each
STi Yellow Side Feed Injectors $125
MAP Sensor Denso #22012AA210 $40
Boost Control Solenoid Valve (Fits All 2005-2020 Models) #16102AA380 $25
Purge Valve $20
AC Compressor Denso #447260-7940 $100
AC Compressor Bracket $15
Alternator $65
Harmonic Balancer / Crank Pulley $40
TMIC Breather Lines $20
Coolant Pipes $20
Up Pipe Brackets $5
Engine Cover Bracket (Sits on top of PS, AC & ALT) $5
Gauge Cluster Auto $50
ECU Auto #22611AJ18B $50
Tweeters $20 set
04 Impreza RS
EJ25 Short Block Complete but Spun Rod Bearing $300
EJ22 Phase I Long Block Fully Assembled $350
EJ22 Phase I Short Block Fully Assembled $250
EJ22 Phase I Heads Complete $200
Crankshaft Pulley $30
Injectors $40
Plug Wires $30 set
Ignition Coil $30
Fuel Rail Covers $20 set
IAC Sensor A33-661 R02 #22650AA192 $20
GD WRX & STi Parts
Engine & Drivetrain Pics: EJ257 Crankshaft $200
EJ257 Crankshaft $100 (Spun Rod Bearing)
EJ257 Pistons $100 set
EJ205 Short Block Complete but Needs Rebuilt $300
EJ205 Case Halves $200
EJ205 Crankshaft $100
EJ205 Rods $75 set
EJ205 Pistons $75 set
AVCS Cam Gears: IN RH #13320AA000, IN RH #13320AA001, IN LF #13322AA000, IN LF #13322AA001 $75
STi AVCS Left Intake Camshaft #13037AA352 $100
OEM Turbo Oil Line $25
OEM Turbo Heat Shield $20
OEM Turbo Heat Shield Bracket $10
Up Pipe Brackets $10
05 WRX Fuel Pump Controller $50
STi Passenger Side Feed Fuel Rail with Lines $25
JDM SG5 Intake Manifold $100
JDM SG5 Throttle Body DBW #16112AA003 $100
04 WRX Intake Manifold $100
Intake Resonator $20
OEM Intake Scoop $20
Intercooler Brackets $10
Cat, Crossover and Manifold Heat Shields $10
Catless Downpipe (Slip on style/No flange for cat back) $75
Competition Clutch OEM STi Replacement #99707-S $50
OEM WRX Pressure Plate $50
Clutch Fork $20
Clutch Line $15
PCV Hose Assembly #11815AB711 $20
Crankshaft Sensor $20
Camshaft Sensor $20
Knock Sensor $20
Rear O2 Sensor 03-07 WRX STi and 04-08 FXT & Baja #22690AA520 $35
Front O2 Sensor Cover $5
Timing Covers $15
Timing Belt Guide $10
Timing Belt Tensioner Bracket $15 #13156AA062
Flywheel Cover $10
OEM Water Pump & Thermostat $50
OEM Harmonic Balancer / Crank Pulley $40
Crankshaft Sprocket $20
WRX Shifter Linkage Assembly $50
Front Female WRX Axles $100
Male Front WRX Axle $100
Rear WRX Axles $75
05 WRX ABS Module $50
06 WRX Proportioning Valve $20
Oil Pump $50
EJ205 Valve Covers $40 set
OEM Boost Controller (Fits 04-07 WRX STi) #16102AA360 $50
Boost Solenoid Controller Bracket $5
JDM 02/03 Power Steering Pump w/Bracket $100
Power Steering Pump Bracket $15
Power Steering Reservoir $20
Power Steering Reservoir Bracket #34633FE001 $10
Transmission Mount $20
Alternator #23700AA430 $65
OEM Alternator Belt Cover $10
AC Compressor $100 #73110AE020, #73110AE021, #73111FE040 & #73110SA000(JDM)
AC Compressor USDM & JDM Bracket $15
AC Lines $30
Coolant Overflow $20
Metal Coolant Reservoir Expansion Tank $35
Coolant Hard Lines $20
Coolant Temperature Sensor $10
Oil Pan & Baffle $50
Oil Pickup $15
Oil Cooler $75
Oil Dipstick $10
Oil Cap $5
Oil Fill Neck $10
Washer Fluid Tank $20
02-05 WRX Cruise Control Actuator Module $20
Hood Prop Rod $5
Rear Differential "T" Crossmember $50
Transmission Crossmember $50
Engine Mounts $40
Pitch Stop $10
WRX Flex Plate with Hardware $40
Suspension, Wheels, Tires, & Brakes Pics: OEM Rear Lateral Links $40 set
Trailing Arms $40 set
Control Arms $50 set
Front Knuckles $50
Driver Rear Knuckle $75
04 WRX Sway bars $25
04 WRX Front Calipers $50
04 WRX Front Rotors $25
04 WRX Rear Rotors $25
04 WRX Brake Booster $50
04 WRX Brake Master $40
Front ABS Sensors: #27540AE000, #27540AE001, #27540AE010 $20
OEM STi 5x114 Rotors $50 set
5x100 Spare Tire $25
Jack & Handle $10
Exterior Pics: 04 WRX Grille $75
04 WRX Passenger Fog Light Trim $25
Front Sedan/Wagon Doors PSM $150
Rear Wagon Doors PSM $150
Passenger Rear Sedan Door PSM $150
WRX Wagon Roof Rails $75
06 WRX Rear Bumper Beam $100
Rear Bumper Styrofoam $10
Gas Lid SGM $20
Wiper Arms $30
Wiper Motor & Linkage $40
Wiper Cowl $25
Exterior B Pillar Molding with Weather Stripping $20
Driver A to C Pillar Trim $40
Passenger Rear Exterior Upper Door Trim $15
Fuel Fill Neck $30
Fuel Fill Neck Cover $10
Interior Pics: 06 WRX Black Front Seats $400
04 WRX Door Cards $100
Bugeye Door Cards $50
04 WRX E-brake Handle $25
04 WRX Center Console $50
04 WRX Shifter Bezel & Boot $25
Dash $100
Dash Bar $50
Lower Dash Panel $25
Console Coin Holder $10
Lower Dash Panel Bracket $10
Glovebox $50
Cluster Surround $20
04 WRX Center Air Vents with Hazard Switch $30
04 WRX Radio & HVAC Trim $25
Heater Core $75 #72110FE101, 72110FE033 & 72110FE110
Blower Motor $75 #72210FE020
04 WRX Steering Column $50
05 WRX Steering Column $50
06 WRX Steering Column $50
Steering Column Trim $20
Map Light $25
Dome Light $20
3rd Brake Light $20
Visor Clips $5 set
Rear View Mirror $20
Interior Mirror Covers #94251FE000 & 94251FE010 $5
Interior A Pillar $20
Interior Upper B Pillar Trim $10
Interior Lower B Pillar Trim $10
Interior C Pillar Trim $10
Rear Seat Trim $10
Door Kick Molding Trim $10
Driver Center Console Side Cover $10
Rear Heat Vents $10
Seat Belts $40
Passenger Front Seat Belt Buckle $20
Rear Seat Belt Buckles $10
Gas Lid Release Cable $10
Trunk Latch $10
Trunk Latch Trim $10
WRX Trunk Torsion Bars $20
Weather-Stripping $5
Fuel Pump Cover $5
Jack & Handle $10
Jack Cover $5
Rear Dash $40
Parking Light Combo Switch $20
Sedan Sunroof Headliner $40
Sunroof Trim $10
Sunroof Drain Tubes $10
Electronics Pics: GD Electronics
ZTEC 9007 HIDs New $40
2004 WRX Engine Harness $100 (Wired for side feed but will come with top feed connectors with pigtail)
2005 WRX Cluster Harness #81302FE210 $25
2004 WRX Rear Harness #81502FE170 $50
04 WRX Sunroof Wire Harness #81801fe100 $20
Boston Acoustic SE60 6.5" Component Speakers with Crossovers & Tweeters $75
OEM Front Speakers $20
OEM Rear Speakers $20
Speaker Brackets $10
04 OEM Tweeters $10
02-04 Mirror Switch $10
05-07 Mirror Switch $10
Hazard Switch $10
Map Light $20
Dome Light $20
Headlight/Blinker Combo Switch $25
Wiper Combo Switch $25
Switch Blank $5
Rear Defrost Switch $10
Fog Light Switch $10
Cruise On/Off Switch $10
Cruise Control Switch $25 #83151AE000
OEM Horns Set of High & Low $10
Horn Switch (Behind Airbag) $10
Metal ECU cover $10
Wiper Motor $40
Positive Battery Terminal Cable $5
04/05 WRX Fuel Tank Wiring $20
DRL Module #84067FE060 $10
04/05 Control Unit Air Bag #98221FE110 $30 (2 available)
WRX STI Left Front Air Bag Sensor #98231FE070 $10
WRX STI Right Front Air Bag Sensor #98231FE060 $10
WRX STI Left Side Airbag Sensor #98235FE150 $10
WRX STI Right Side Airbag Sensor #98235FE140 $10
WRX STI Left Side Airbag Sensor #98231FE010 $10
WRX STI Right Side Airbag Sensor #98231FE000 $10
Airbag Harness $25
WRX STI G Sensor ABS #27540FA022 $10
WRX STI G Sensor ABS #27540FE090 $10
Fuel Injector Resistor Module #684227 $10 (2 available)
Door Ajar Sensors $20 set of 4 (2 sets available)
04/05 WRX STi Keyless Entry Module #88035FE140 $20
06/07 WRX STi Keyless Entry Module #88035FE190 $20
04/05 WRX STi Integrated Control Module #88281FE160 $20
Security ECU #h7110ss010 $25
WRX STI Clarion Antenna Amplifier Assembly #86327FE090 $20
More Pictures
04 WRX Parts:
Turbos, TMICs, Intake & Exhaust Manifolds, ECUs and Wiring Harnesses:
imgur.com
EJ20 Heads & Accessories:
Timing Covers, Intake Parts & Radiator Fans
EJ20 Block, Heads, Intakes & Accessories:
04 FXT
Rear Sway Bar $25
Pistons $25 each
Timing Covers $15
BPV Hose $10
OEM Inlet $20
Purge Valve $20
Alternator $65
Coolant Pipes $20
Up Pipe Brackets $5
Tweeters $20 set
04 Impreza RS
Injectors $40
Plug Wires $30 set
Ignition Coil $30
GD WRX & STi Parts
EJ205 Rods $75 set
Clutch Fork $20
Clutch Line $15
Camshaft Sensor $20
Knock Sensor $20
Timing Covers $15
Flywheel Cover $10
Rear WRX Axles $75
Oil Pump $50
AC Lines $30
Oil Pickup $15
Oil Cooler $75
Oil Dipstick $10
Oil Cap $5
Oil Fill Neck $10
Hood Prop Rod $5
Engine Mounts $40
Pitch Stop $10
Front Knuckles $50
Jack & Handle $10
Gas Lid SGM $20
Wiper Arms $30
Wiper Cowl $25
Fuel Fill Neck $30
Dash $100
Dash Bar $50
Glovebox $50
Map Light $25
Dome Light $20
3rd Brake Light $20
Visor Clips $5 set
Rear Seat Trim $10
Rear Heat Vents $10
Seat Belts $40
Trunk Latch $10
Fuel Pump Cover $5
Jack & Handle $10
Jack Cover $5
Rear Dash $40
Sunroof Trim $10
04 OEM Tweeters $10
Hazard Switch $10
Map Light $20
Dome Light $20
Switch Blank $5
Metal ECU cover $10
Wiper Motor $40
Airbag Harness $25
More Pictures
04 WRX Parts:
GD 2 - Turbos, TMICs, Intake & Exhaust Manifolds, ECUs and Wiring Harnesses
Imgur: The magic of the Internet
