1 - 10 of 10 Posts
Now that the heat of summer is upon me, I've noticed that the vents blow hot air all the time (unless I'm running the A/C, of course). It's noticeably hotter than the outside air temp. Seems like heat soak from the engine compartment, because it's not bad when I pull out of the garage in the morning, but it gets hotter as I drive. Once the sun heats up the car, all I get is hot air. I hate running the A/C, but sometimes I wuss out and use it anyway.
Has anyone had any luck fabricating a heat shield or insulating the intake plenum for the cabin vents? Maybe a sheet of asbestos or some header wrap in strategic places will help me out.
You have air coming out because you do not have it closed. Slide the lever over that is under the fan/temp dials, that will stop the air from coming in. One is for outside air and the other is recirculate.
-joe
Discussion Starter · #3 ·
I've got it set to outside air, are you saying it should be on recirc? I don't understand why you'd use recirc, as you'd just be pushing warm cabin air around.
But then you will not have hot air pumping in from the outside. Try it, see if it makes a difference.
-joe
Re-Addicted to WRX
Open a window...;)
i dont understand- if the blower motor is off, no air should be circulating especially on recirc.
*tip- the coldest air is always on recirc.
I, too, notice this warm/hot air in the cabin. It's much hotter than ambient. I haven't figured out where it's coming from, but it's not coming from the vents. I even feel it with the AC on. I am thinking that somehow the under the hood air is leaking into the cabin somewhere. It's actually worse with the windows down. I would love to hear more about this.
Re-Addicted to WRX
I always thought that the short burst of hot air that you get (even with the A/C on) is from the heated air between the dash and the windshield. I assumed that this area does not get very much circulation from the a/c vents unless you put on the windshield vent...try that and see if it works. At any rate...if the sun is hot enough outside and it is bearing down on your dash I don't think that the a/c will be able to replace all of the air that is being heated... my .02.
A car is not air tight, on outside if you are moving air will be forced through, even on recirc you have to have some fresh air or we would die.
Re-Addicted to WRX
To add to my previous post...I noted that the heated air seemed to come out of a nowhere (or everywhere)...after I got my windows tinted it seems to come more from just the windshield area.
I agree with Trypsin that the car is not air tight, however I tend to feel them more when the car is stopped, which would suggest that outside air flow is not a contributing factor.
1 - 10 of 10 Posts
