1 - 6 of 6 Posts
Every time a post something, everybody asks me what I have done to my car, well here it goes......
2.4 Litre stroker conversion kit.
Long-throw crank, forged rods, forged pistons (giving around a 7.5:1 CR), heavy duty bolts rings and bearings.
Heavy Duty O-ring's, copper head gaskets and heavy-duty head studs.
Custom top section exhaust manifold.
Turbonetics roller-bearing T60/70 turbocharger. (Currently at 30psi)
42mm external Turbonetics Racegate. (wastegate)
Pneumatic pressure regulator.
PWR (Paul Weel Racing) bar-and-plate front-mount intercooler.
Throttle flipped onto the leading side of the intake manifold, giving a more direct airflow path - but at the expense of having to remove the air conditioning system.
RBR blow-off valve (soon to be replaced).
Silicone hoses and heavy-duty hose clamps.
Oil catch can.
MicroTech MTX8 engine management system.
Four hi-flow 800cc injectors.
In-boot surge tank and Bosch Motorsport pump with a Malpassi rising rate regulator.
Standard ignition coils with a MSD booster (Microtech controlled).
4200lb pressure plate and brass button clutch.
Tony Rigoli supplied full customized dogbox.
Upgraded grooved and cross drilled discs using standard 4-piston calipers with upgraded pads.
Lowered 1.5 inches with pedders springs and shocks.
17-inch gold Turismo wheels.
22B style rear spoiler.
Interior standard.
There it is, a full list of my mods.
Discussion Starter · #2 ·
I knew I would forget something.......
3 and a half inch full mandrel bent exhaust with one cat.
thats all of it.
Discussion Starter · #4 ·
Power: 469hp @ wheels
Torque: Too Much!
0-60mph: Too Quick!
Quarter Mile: 10.4 sec @ 134mph
Very, very impressive list of stuff Wrex4Life (and with equally impressive numbers)! How long have you been working on this project? Seems to me I read somewhere (in that article about your car, I think) that you bought the engine from Rigoli when they took it out of their rex. Is that accurate?
Rod
1 - 6 of 6 Posts
