1 - 8 of 8 Posts
Hey fellas how are yas.. i’ve noticed recently i’m roughly only getting from a full tank 200-250kms as before i was roughly getting 350-400 a tank.. i know nothing about engines fuel etc what should i start with
If there is an error code, diagnose that. If not, look for vacuum and boost leaks. If no luck there say hi to your local specialist.
First thing is considering a change of driving habit. Then doing any maintenance on the engine it may need. New brakes, new joints, new tires, new fluids will all help with fuel economy
how do i check for boost leaks ??? i’ve actually thought that sometimes it sounds like there’s a leak well it sounds different under boost sometimes 😫😫..may be a trip down to the mechanic
It's not as straightforward and checking for vacuum leaks I'm afraid. See if a visual turns anything up. If not, make a contraption to pressurize the intake (there are instructions floating around here and/or online) and go from there.
So i may have found my issue i had a bolt missing on the exhaust hope that’s it anyway... so monday getting that fixed an a tune
Æternum
Sounds like you are taking a stab in the dark....
Discussion Starter #8
yeah that stab in the dark has helped😯 half a tank of fuel an already clocked 230kms so i’m hoping 460kms to a full tank is doing good for a 2001 model driving around town..
1 - 8 of 8 Posts
