The Swift Spec R Springs for the 2015+ Subaru WRX is made for the true track racing enthusiasts that wants to take their car to the next level. If you want to lower your vehicle and improve performance without the hassle of coilovers this is the best option for you!
Sport Springs Spec-R is engineered with 3 main characteristics:
Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. The Spec-R is increased to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
Maintaining optimal comfort level for street use.
Applications:
Subaru WRX [VAG] (2015, 2016, 2017)
Features
Ride Height Drop: 1" / 1" (front / rear)
Spring Rate: 6.0kg/mm (335lbs/inch) / 7.2kg/mm (402lbs/inch) (front / rear)
Built for OEM Shocks
Performance Springs
Brief use maybe 3k miles bought Ohlins RT coil overs
Will take $269.00 delivered CONUS. Includes two front and two rear Swift springs
2015-2017 Subaru WRX Whiteline Strut Mount Offset Assembly also available....... will deal on both due to shipping in one box.
Applications:
Features
Performance Springs
