1 - 17 of 17 Posts
Wondering if anyone could help me identify this front mount, Ive been told its turbo xs and Ive been told its an ebay knockoff.
Gold Member
It's either the turboxs, or a darn good copy of one. This is the turboxs:
Take a picture of the internal fins
Sent from my Droid using Tapatalk
janderson13 said:
There is the internal fins.
Tough to tell after being used for a while, but that looks like a knockoff to me.
janderson13 said:
Ok thank you ej257, now from here do I spend the money and get the perrin or stick with this one?
What turbo?
janderson13 said:
amr t60, shooting for 500whp or more, getting it tuned and built by agile.
A better core would probably help, but isn't necessary depending on your budget.
Discussion Starter #11
Agile claims that in order to get 500whp they have to go rotated, amr got 400whp with a top mount and 500whp with a frount mount.
Different dynos. Different tuners.
When you get into turbos of that size, rotated is the way to go.
Pro Manscaper
+1 to Matt...
Just use what you have and see how high you can go reliably...getting over 400whp, its gonna roast all 4 tires anyway, so just enjoy that for awhile :)
No, you don't have to go rotated, that just makes it easier and better to drive. For a stock location setup you'll need a larger turbo to get the same numbers because of the flow restrictions, which means it will spool even later. Even if you were using the same size turbo the rotated setup would spool earlier and make more peak power.
1 - 17 of 17 Posts
