1 - 5 of 5 Posts
G
HEY! I just got my Cusco Sway Bars installed. I dirve a 2003 Subaru Impreza 2.5rs but I beleive the suspension set up si the same. I am having a problem. One part of the sway bars seems to be rubbing on the exhaust pipe they tell me. This causes lots of vibrations in my car before I get to 1.5-2.0 thousand rpms. Has anyone ahd this problem? How do you fix it? PLEASE HELP!?
Moderating on the run!
Front sway bar rubbing on exhaust?
What sway bar did you get? The front sway bar for the WRX sedan is different than the one for the WRX wagon and RS as the sedan utilizes a pillowball sway link in the front.
Provide more info.
Big Sky
G
Discussion Starter · #3 ·
I got a cusco sway bar and I tihnk it was built for the wrx, not the 2.5rs, but they said it should fit no problem.
I'm 99% certain the WRX sedan front bar won't work w/ the wagon or RS, the rear bars all interchange. Front sedan links won't help as the lower link attachment is different as well.
Time to call your vendor.
Big Sky
1 - 5 of 5 Posts
