1 - 8 of 8 Posts
· Registered
Tire Wheel Vehicle Car Plant
$25,000 or best offer
9,500 miles on new motor
IAG Stage 2 Tuff short block
Heads checked, pressure tested and
machined as needed
Valve job
Cossworth springs
Tomei cams
ARP head studs
11mm oil pump
New oil cooler
New OEM belt and all idler pulleys and
tensioner
All new OEM seals and gaskets
Killer bee pan
Killer bee pickup
321 stainless steel equal length header
Blouch 1.5 with 10cm exhaust housing
Tial EWG
ID1300 injectors
Cobb flex fuel kit
Aeromotive regulator
-6 fuel lines
ID fuel rails
TGV deleted
Cyl 4 cooling mod
Perrin big MAF
Cobb 4 bar map sensor
Cobb EBC
Grimmspeed TMIC
Forge BPV
Crawford AOS
South Bend stage 2 enduro clutch and
pressure plate
ACT lightweight flywheel
Driveshaft Shop carbon fiber driveshaft
Bilstien coil overs
Invida exhaust and downpipe
18" Rota G force new tire
Just pro tuned by JR
New OEM front and rear axels installed
Hawk front and rear brake pads
DBA front and rear rotors
Just detailed,polished, buffed and ceramic coated
Facebook-tyler pope
· Registered
Discussion Starter · #2 ·
Tire Car Land vehicle Vehicle Wheel
machined as needed
Valve job
Cossworth springs
Tomei cams
ARP head studs
11mm oil pump
New oil cooler
tensioner
Killer bee pan
Killer bee pickup
Tial EWG
ID1300 injectors
Cobb flex fuel kit
-6 fuel lines
ID fuel rails
TGV deleted
Cyl 4 cooling mod
Perrin big MAF
Cobb EBC
Grimmspeed TMIC
Forge BPV
Crawford AOS
pressure plate
Bilstien coil overs
Facebook- Tyler pope
· Registered
Discussion Starter · #3 · (Edited)
Car Tire Sky Wheel Vehicle
machined as needed
Valve job
Cossworth springs
Tomei cams
ARP head studs
11mm oil pump
New oil cooler
tensioner
Killer bee pan
Killer bee pickup
Tial EWG
ID1300 injectors
Cobb flex fuel kit
-6 fuel lines
ID fuel rails
TGV deleted
Cyl 4 cooling mod
Perrin big MAF
Cobb EBC
Grimmspeed TMIC
Forge BPV
Crawford AOS
pressure plate
Bilstien coil overs
Facebook- tyler pope Car Tire Sky Wheel Vehicle
· Registered
Discussion Starter · #5 ·
Wheel Car Tire Land vehicle Vehicle
Car Vehicle Land vehicle Motor vehicle Steering part
machined as needed
Valve job
Cossworth springs
Tomei cams
ARP head studs
11mm oil pump
New oil cooler
tensioner
Killer bee pan
Killer bee pickup
Tial EWG
ID1300 injectors
Cobb flex fuel kit
-6 fuel lines
ID fuel rails
TGV deleted
Cyl 4 cooling mod
Perrin big MAF
Cobb EBC
Grimmspeed TMIC
Forge BPV
Crawford AOS
pressure plate
Bilstien coil overs
· Registered
Discussion Starter · #6 ·
Sky Cloud Car Vehicle Land vehicle
Sky Tire Wheel Car Vehicle
machined as needed
Valve job
Cossworth springs
Tomei cams
ARP head studs
11mm oil pump
New oil cooler
tensioner
Killer bee pan
Killer bee pickup
Tial EWG
ID1300 injectors
Cobb flex fuel kit
-6 fuel lines
ID fuel rails
TGV deleted
Cyl 4 cooling mod
Perrin big MAF
Cobb EBC
Grimmspeed TMIC
Forge BPV
Crawford AOS
pressure plate
Bilstien coil overs
· Super Moderator (Actually a SuperSpy)
I attempted to merge OPs various threads scattered across the site into a single sales thread here, with limited success. I've notified OP via the notice box when merging.
1 - 8 of 8 Posts
