I would NOT replace it with a TD04 again.
The advice of a used STI takeoff VFXX is a good one; you should be able to get one of those relatively inexpensively. While you don't NEED injectors / pump / boost controller for an STI takeoff turbo, you're going to be getting custom calibration anyway, so now is the time to do it. Any VF turbo is going to basically max out your fuel system, so this would give you some safety margin, and the ability to run E85 in the future. You want ID1050X injectors, if you decide to upgrade. You will absolutely want to have an aftermarket turbo inlet (e.g., Perrin) available when you do the swap, as the OE inlet is notorious for tearing during turbo swaps. If you decide you don't want to use it, you can always resell it, but have it available for the install in case it becomes mandatory.
The other option which I think is worth considering, is an 18G turbo. For example, the Blouch 18G-XT (
link) is a great DD turbo on the 2.5L platform (you would probably want to opt for the 8cm housing). While peak boost comes on later in the RPM range than a VFXX, the increased airflow of the Blouch unit means the powerband doesn't really shift much, and it holds power a lot better towards redline. Coming from a TD04, you'll fall in love with your car all over again with the Blouch.
I think a well-built 18G setup (EL manifold, EWG, TGV deletes) is about ideal on a 2.5L for that serves as both DD/weekend duty.
