1 - 5 of 5 Posts
I want to run ethanol, however, I'm not sure if it's the best idea because I just have the stock block, magnaflow catback, cobb catted downpipe(3"), cobb sf intake, and deatschwerks fuel pump. The only thing that I need in order to run ethanol that i'm aware of is new injectors. Thoughts, concerns?
Æternum
Injectors, engine management and ethanol compatible fuel lines. I would STRONGLY suggest an ECA.
Discussion Starter · #3 ·
engine management and eca? I'm aware of the lines, not familiar with those two however.
Æternum
Get familiar. You already run a Cobb accessport, so you have engine management covered.
ECA = Ethanol Content Analyzer
E85 is rarely 85% ethanol. The actual ethanol content varies from 50% to 95% which means that fueling and timing need to be optimized for a wide range of ethanol %. Flex fuel employs an ECA and automatically interpolates between maps for various ethanol content. If you are cheap/lazy, you will still need an ECA to ensure that the ethanol % is within acceptable range to run on your ECU's state of tune.
1 - 5 of 5 Posts
