1 - 11 of 11 Posts
I have flashing check engine light most mornings going to work the throttle seams to stutter and shakes...seams to stop after my car is warmed up properly... I’ve changes possible problems such as spark plugs and coil packs and still no soulution... plzzz send help
Post the CEL codes.
The check engine light (CEL) is flashing because there is a fault. This fault is stored by the computer and its identity can be retrieved in the form of a code for troubleshooting purposes. You can connect a code reader to the car to retrieve the code(s).
Discussion Starter · #5 ·
I can get the codes after work ... I also woke up to a solid check engine loss of traction control and flashing cruse... I know that the solid light is a misfire is cylinder 1 becuse that was a problem before that I changed coil pack and spark plug but I guess it came back a month later but I will definitely check for codes after work
If you post the codes also post the model of car.
Æternum
The flashing CEL on a Subaru often indicates a gross misfire. It may or may not store a code.
Typically a misfire this severe is indicative of a fueling problem, or (rarely) a spark problem that affects more than one consecutive cylinder in the firing order. It is unlikely that two coilpacks would go bad simultaneously. I would suspect a fueling issue. Check fuel pressure before the injectors, look for FPR problems (the FPR is slaved against manifold pressure, so make sure that the vac line is connected and sound). This will tell you a lot. Is the car unmodified?
Discussion Starter · #9 ·
Sorry for not replying broke phone and just got new one... my car engine is bone stock except a hks blowoff valve and the code that poped up was p0301 cylinder 1 misfire... that code has come up before and went away for about a month after I changed coil pack and spark plug
Æternum
Remove and replace the BOV with the OEM piece. They often leak and cause a lean condition at low loads. That may be what is causing your misfire. Also it serves no purpose .
Discussion Starter · #11 ·
i Just recently put on the blow off valve... i had the code before I put it on ... I’ll try switching it back and see if that fixes anything
1 - 11 of 11 Posts
