Asking Price: 32k
Mileage: ~33,500 on the body (~7,500 on the built motor)
All the major work and tuning was done by FLI in Santa Rosa, CA, and by the machine shop that they use.
I'm selling the car because I don't drive it much, and I'm moving on to a different phase in my life.
I hope to sell it to someone who will actually drive it and appreciate it.
I have documented all the work and maintenance that was done, and what mileage it was done, as well as dyno sheets for the car (425 whp on Meth map on 91 octane, 405 whp w/o Meth on 91 octane).
I had the hood repainted 6 months ago, and just had the bumper redone (so there are almost no chips or imperfections that usually occur in that area).
Moved recently from CA, but the car has Florida registration and plates now good until late next year.
Engine
Cosworth Standalone ECPro ECU
Cosworth Camshafts
Heat-Treated Crankshaft
ACL Race Bearings (Rod and Main)
Eagle H-Beam Connecting Rods
JE Pistons/rings
GSC SS 32 mm Exhaust Valves
GSC SS 36 mm Intake Valves
GSC Valve Springs w/ Titanium Retainers
Beatrush Alternator Pulley
Perrin Front Mount Intercooler (Stealth Black)
Crawford Air Oil Separator
Killer B Oil Pickup, Baffle, and Oil Pan
Killer B Radiator Shroud
Mishimoto Dual Core Aluminum Radiator
Samco Radiator Hoses
TGV Delete
KS Tech Air Pump Delete
ATP GTX 3576R EWG Stock Location Turbo
GFB Response Adjustable BOV/BPV w/ OEM Adapter
Tial MV-R External Wastegate
Custom EWG Dump Tube (rerouted near the end of the downpipe
KS Tech 83mm Intake
AVO 3" Silicone Turbo Inlet Hose
Grimmspeed Phenolic Thermal Spacers (8mm)
Invidia Catless Downpipe
Invidia Q300 Catback
Wideband O2 Sensor
Injector Dynamics 1000cc Injectors
MSI Fuel Rail Kit
Tomei Adjustable FPR
Tomei Equal Length Headers / Uppipe
Tomei FPR Gauge and Adapter
DeatschWorks DW65C Fuel Pump
Aquamist HFS-2 Meth Injection Kit w/ Howerton Engineering Trunk Enclosure
Group N Motor Mounts
Group N Pitch Stop Mount
Drivetrain
PST Carbon Fiber Driveshaft
ACT HDSS Clutch Kit
ACT Streetlite Flywheel
Group N Transmission Mount
Kartboy Short Throw Shifter
Kartboy Front and Rear Shift Bushings
Whiteline Transmission Crossmember Bushings
Whiteline Rear Differential Mount Bushing Inserts
Whiteline Rear Subframe Bushing Inserts
Suspension
Stance Coilovers
Whiteline Steering Rack Bushings
RCE Sway Bars (25.5mm)
Perrin Spherical Endlinks Front and Rear
Other
Anarchy Mammoth Shift Knob
Lightweight Battery
Porterfield RS-4 Brake Pads
Stoptech SS Brake Lines
Grimmspeed Master Cylinder Brace
ThermoTec Heat Wrap (Headers, Uppipe, Downpipe)
Kartboy Exhaust Hangars
