21 - 32 of 32 Posts
Discussion Starter · #21 ·
As i am still learning, i dont know all the readings on AP, I do know, however all i did was reset ecu. I then went and looked at tuning and it said current map was the "mikey tune" which is the guy who did it originally so, i REALLY doubt i accidently put it to valet mode.
The gas is getting drained this afternoon.
In Æternum
Since this is a custom tune, you REALLY should be having the conversation with Botti.
He should support his own calibration effort.
Discussion Starter · #23 ·
At risk of sounding ignorant... I don't know who Botti is, lol
After a search, I came across PhatBotti tuning? I'm guessing this guy travels to shops and tunes cars? The local Subaru buy at boxer motorsports did mention he has a tuner come around every now and again and tunes a bunch of cars over a few days and then leaves.
Discussion Starter · #25 ·
Havnt contacted anyone outside boxer motorsports.
I did however cleaned iacv(wastn real dirty) new gasket, cleaned MAF(was pretty dirty, the one side of the little bulb was anyway). Replaced ALL gas this time... went for a drive. Idles ok now... drove around modestly until engine warm, then slowly statted to get on it. Once i got to 6psi boom it happened again. I tried once or twice more and same result. The engine cuts out at 6psi. Maybe 7.. research continues
Discussion Starter · #26 ·
Back from the dead…
so the last year and a half been going through a horrendous divorce. FINALLY got my car back yesterday. Drained the old fuel, got a new battery and fired right up.
and right back where we left off. Car won’t go over 3500rpm. Just stumbles and spitters and rev bounces.
I livr in an apartment now with no real way to “work” on the car. :\. Will start posting vids for review
Not a mod... or is he?
Just check for codes. Some codes will be present in the stored codes folder but not trip a cel.
If I recall that's the limp mode limit, so I would expect a code
Discussion Starter · #31 ·
does not throw any codes. no CEL.
I hope this comes out readable. hahah!
Time (sec)AF Learning 1 (%)Boost (psi)Calculated Load (g/rev)Dyn. Adv. Mult (DAM)Dynamic Adv. (°)Feedback Knock (°)Fine Knock Learn (°)Ignition Timing (°)MAF (g/s)MAF Volt. (V)RPM (RPM)TD Boost Error (psi)Throttle Pos. (%)Wastegate Duty (%)AP Info:[AP3-SUB-001 v1.7.3.0-17905][2002-2003 USDM Impreza WRX][Reflash: MikeyTuned_TD04_16psi+-1psi.ptm - Realtime: MikeyTuned_TD04_16psi+-1psi.ptm]
000.561.181680029.554.722.8227865.7231.472.550
0.01200.911.211680029.557.792.8227865.8431.872.550
0.06701.081.22168002857.112.8228746.2132.972.550
0.1201.451.25168002762.952.929575.833.372.550
0.17801.781.261680025.563.132.8629125.834.572.550
0.27502.111.28168002564.052.930006.0737.672.550
0.30602.611.331680024.569.032.9630616.4638.872.550
0.37403.231.391680022.572.62330616.3850.272.550
0.42703.891.43168002176.773.0831508.9963.972.550
0.48704.541.5168002080.963.14320112.0975.372.550
0.55205.11.55168001985.863.18320114.8985.572.550
0.62705.651.59168001985.863.22334414.3396.972.550
0.67906.341.66168001889.713.3330813.6710072.550
0.73306.651.791680016.593.093.16330713.1310072.550
0.79706.381.731680017.584.573.26362613.5210072.550
0.85306.961.921680016.590.143.3333012.9410072.550
0.9206.881.821680017.5101.933.28358213.1110072.550
0.97706.942.06168001690.613.22349613.0710072.550
1.04506.881.99168001690.033.34178613.0110072.550
1.11106.771.91680016101.33.341786-1.2410069.410
1.16406.831.871680010100.893.421848-0.9910067.840
1.2307.141.881680010106.283.441879-1.5910065.880
1.29307.352.091680010107.33.41849-1.5910065.880
1.3506.852.181680016.592.233.4377013.0310071.760
1.41506.632.33168008104.533.281842-1.4710068.630
1.47606.192.151680015.595.913.3368913.6710072.550
1.54106.342.31680015101.383.32200713.410072.550
1.60406.42.121680016.5106.283.44389013.6110072.550
1.66507.272.091680015112.133.4364612.7810072.550
1.72306.922.28168007112.133.261812-2.0310068.240
1.79706.272.14168009.599.73.3820111.2410070.20
1.84906.342.281680013.5101.573.24372613.5675.372.550
1.91405.922.47168009100.133.41986-2.133.967.840
1.9690-3.211.321680012108.321.8436485.16000
2.0370-7.140.59160003414.751.4235118.93000
2.1030-8.760.271600033.55.821.24333910.94000
2.1570.78-9.840.161600022.53.261.24316411.89000
2.220.78-10.440.11600022.53.191.24316412.51000
2.2780.78-10.770.0816000263.021.2302912.86000
2.3380.78-10.960.071600021.52.661.18288912.86000
2.4170.78-11.120.061600017.52.721.2275112.99000
2.4610.78-11.290.0716000142.951.22261613.11000
2.5260.78-11.390.081600011.53.571.28248613.32000
2.6020.78-11.430.091600011.541.28238513.38000
2.6550.78-11.470.091600011.54.021.32226713.46000
2.7090.78-11.450.11680011.53.741.32218313.4617.600
2.7720-9.030.4168002632.362.6421219.2434.530.20
2.8310-0.540.921680030.532.362.7223236.345.532.550
2.89700.061.03168003256.092.7269811.0463.934.90
2.95700.391.11680034.549.482.8270414.1965.937.650
3.0201.041.2168002757.452.74253410.7765.9400
3.08301.041.19168002953.142.8280914.4870.242.350
3.14201.591.261680024.556.942.78255011.1270.645.10
3.20601.841.24168002656.942.82283215.6881.247.450
3.26402.151.27168002657.452.82283212.7683.550.20
3.32902.651.281680023.559.842.82261715.2296.552.550
3.39202.781.31680024.561.582.86284013.1910052.550
3.4503.351.371680022.565.92.92270513.1910054.90
3.51603.521.38168002264.052.92283814.4110057.650
3.57404.061.42168002168.662.98280713.75100600
3.63504.371.42168002065.712.98283813.6110062.350
3.71204.741.48168002073.63.02288213.7910065.10
3.76605.181.511680019743.06291713.7110067.450
3.81905.531.571680018.580.553.12296213.9810069.80
3.88206.051.581680017.580.553.06296813.4810072.550
3.94906.41.621680017.579.363.16298613.3810072.550
4.00406.751.641680017.583.073.16304413.1510072.550
4.06506.921.681680017.585.213.2302512.9710072.550
4.12807.151.671680017.587.363.18307812.7410072.550
4.19107.231.681680017.585.863.18311012.6310072.550
4.25507.291.691680017.585.643.2314412.6710072.550
4.32207.291.691680017.589.53.23144-2.410067.450
4.37606.651.74168009.588.863.2155413.2110072.550
4.43906.941.911680017.588.223.24341810.9610072.550
4.49706.91.71680015.582.393.02295010.9610072.550
4.5607.081.89168001896.143.26346712.9910072.550
4.62306.981.72168001782.213.16321012.8210072.550
4.68807.331.83168001096.613.321693-2.1910067.840
4.75107.021.82168001689.973.22320412.8810072.550
4.81406.791.931680017.594.733.3350313.2110072.550
4.87307.12.141680016.581.073.16165312.6310072.550
4.9306.281.92168001781.073.2334613.4610072.550
4.99606.671.83168001676.373.1322313.1510072.550
5.05907.041.751680017.580.043.36348312.8610072.550
5.11407.482.061680015102.792.98314412.5510072.550
5.17806.651.881680016.581.453.24353113.2510072.550
5.24207.11.971680015.598.253.28311712.6810072.550
5.30607.061.821680015.5101.663.3221159.4210072.550
5.363071.981680015.598.253.32211513.0110072.550
5.42706.961.76168001698.723.28337812.8610072.550
5.4907.292.011680017.5102.533.38360712.1410072.550
5.55207.151.731680015.598.543.163188-1.0410072.550
5.61707.212.081680011.5102.83.41888-1.0410069.80
5.68106.771.96168001686.283.2347012.7410072.550
5.73406.852.171680017.596.143.32384013.3210072.550
5.79606.7921680015.588.533.2334212.8810072.550
5.85906.772.14168001198.253.420921.9310072.550
5.92406.562.041680017.597.083.36372013.410072.550
5.98106.982.041680016.595.433.28372912.8210072.550
6.04507.12.05168001795.433.36371412.7610072.550
6.10807.1521680015.5101.323.2352212.5392.272.550
6.17206.92.11168001490.013.16353412.9968.672.550
6.23606.191.931680016.597.313.2636912.8218.472.550
6.28904.561.541680019.595.671.7634723.460.472.550
6.3530-7.10.8160002317.291.3217709.050.400
6.4170-9.20.3516000356.411.08337411.39000
6.4820.78-10.520.1516000351.951.08337412.65000
6.5450.78-10.980.081600031.51.170.9324613.09000
6.5990.78-11.370.051600027.51.150.9306813.42000
6.6620.78-11.520.0316000231.150.86293513.42000
6.7390.78-11.470.0316000201.20.96279713.48000
6.7920.78-11.350.0516000162.571.2265613.36000
6.8460.78-11.430.081600011.54.161.34251813.36000
6.9210.78-11.450.091600011.54.191.36244213.38000
6.9740.78-11.450.11600011.54.441.34232513.46000
7.0320.78-11.450.111600011.54.531.36224213.42000
7.10.78-11.350.121600011.54.531.38211813.347.800
7.1540-14.810.181680023.54.651.88203212.2410.230.20
7.2290-8.30.3516800512.262.04200810.2510.232.550
7.2820-7.60.41168004.518.412.0623899.4210.634.90
7.3470-7.50.42168005.518.82.0626659.461137.650
7.4030-7.390.46168009.519.052.1224429.2211400
7.4660-70.49168001321.372.1225648.911142.350
7.5230-6.940.5168001322.542.1225648.861145.10
7.5880-6.610.541680017.523.642.1824758.5111.447.450
7.6520-6.570.55168002124.442.1825238.4911.450.20
7.7160-6.40.56168002524.042.225348.4911.850.20
7.7790-6.150.61680028.524.842.2424968.321.252.550
7.8330-2.530.82168003338.992.625348.1239.654.90
7.8930-0.191.031680036.552.82.7625468.5163.957.650
7.96200.331.121680028.549.962.68252612.387.8600
8.02100.61.14168002848.72.68259014.2510062.350
8.08100.931.181680028.552.012.74251913.0510065.10
8.14101.221.21680027.552.012.72254813.1310067.450
8.20601.471.211680026.551.852.72259413.4410069.80
8.2701.761.23168002652.952.7256412.7210072.550
8.33301.991.24168002654.092.72260612.9710072.550
8.39302.31.26168002554.752.8258912.4910072.550
8.45202.531.291680023.555.912.84257812.0510072.550
8.51602.81.291680023.558.472.78261812.310072.550
8.57403.091.31680023.557.792.78261812.1810072.550
8.63303.311.331680023.556.622.82263211.8910072.550
8.70203.61.36168002260.712.9262812.2610072.550
8.7603.811.4168002161.622.9268012.2610072.550
8.81804.121.43168002064.052.9266811.810072.550
8.88704.371.47168001967.192.92267211.5810072.550
8.94704.641.46168001964.432.9270011.5610072.550
9.00304.891.44168001966.272.94268111.1410072.550
9.07205.221.48168001968.292.98268810.9310072.550
9.13605.411.521680018.569.973.0227141110072.550
9.19405.71.551680017.569.973273210.8910072.550
9.25106.011.561680017.572.643.02272110.510072.550
9.3206.211.561680017.571.483.04274610.5410072.550
9.37906.461.551680017.573.613.04277810.6710072.550
9.44206.691.591680017.570.983.08276110.2596.972.550
9.49606.791.621680017.574.793.12278410.3885.172.550
9.56506.881.611680017.578.553.0428418.3365.172.550
9.62306.771.621680017.575.383.0428413.0237.672.550
9.68205.631.531680017.575.382.982833-0.6814.970.590
9.74704.71.2168001960.372.7628334.430.872.550
9.8090-5.30.611680040.59.811.4628294.430.472.550
9.8730-8.260.316000392.891.227808.990.400
9.9270.78-9.610.161600035.52.371.12285911.120.400
9.9970.78-10.420.091600031.51.631.04280612.160.400
10.050.78-10.790.0616000281.651282812.680.400
10.1140.78-11.220.0516000241.350.98280813.11000
10.1830.78-11.540.0416000201.351.02279913.440.400
10.2380.78-11.830.041600016.51.511.08281313.75000
10.3030.78-11.990.041600012.51.861.08282013.94000
10.3680.78-12.050.041600011.51.841.1280014.020.400
10.4250.78-12.180.041600011.51.951.12279714.14000
10.4850.78-12.280.051600011.52.211.16279614.250.400
10.5490.78-12.360.051600011.52.621.16278714.310.400
10.6120.78-12.410.051600011.52.431.16278714.410.400
10.6680.78-12.450.051600011.52.561.18277014.43000
10.7310.78-12.450.051600011.52.481.16277814.410.400
10.7910.78-12.450.061600011.52.661.18277114.41000
10.8650.78-12.410.061600011.52.991.22275014.41000
10.9150.78-12.380.071600011.53.141.24275314.35000
10.9810.78-12.260.081600011.53.621.3275514.27000
11.0460.78-12.180.091600011.54.271.34273014.15000
11.1090.78-12.120.091600011.54.51.36273014.1000
11.1660.78-12.10.091600011.54.271.34273414.06000
11.2290.78-12.090.091600011.54.271.3271614.04000
11.3010.78-12.10.091600011.53.921.36270614.06000
11.3540.78-12.090.11600011.54.351.38271314.04000
11.4120.78-12.070.11600011.54.591.38270214.02000
11.4780.78-12.090.11600011.54.81.38268514.04000
11.5320.78-12.090.11600011.54.651.34267814.06000
11.5970.78-12.160.11600011.54.331.26266414.12000
11.660.78-12.20.081600011.53.691.26266414.17000
11.7240.78-12.30.071600011.52.971.2264914.27000
11.7780.78-12.380.071600011.52.811.18265414.35000
21 - 32 of 32 Posts
