So I'm running the Stage 1 + SF 91 HWG (not hitting target boost with the NWG). When running the NWG map, I had good AFRs, zero knock, but only see high 13's boost psi. Target boost should be 16 psi though. So with that, I ran the HWG map. Another 3rd gear pull showed max psi of only 14.1, but had a little bit of knock. Can someone take a look at my logs and give me some advice? I'm tempted to just go ahead and stick with the NWG map. Don't want to experience the knocking again. Thanks for any help!
NWG Log
HWG Log
NWG Log
HWG Log
