1 - 2 of 2 Posts
After I got off work I wanted to log a 2nd gear pull to see if I would get FBK during WOT and I actually did. -1.4 around the 5k range. My DAM stayed at 1 the whole time and I got -1.05 FKL after I stopped logging. I just wanted to ask if these are normal numbers to see. I recently installed my AP and I am running Stage0 from cobb OTS. I have a 2018 Wrx sti Li with 24k miles. Stock just a AP.
Hopefully, this is the right category for this thread since I am a new member.
Datalog link datalog4.csv
Æternum
You don't have any learned knock in your log.
You have a couple cases of FBKC, both circumstances at high load. While this is not outright alarming, it should be something to keep an eye on.
Your Fuel Trims in "Cell A" are a bit high. Check for some minor vac leaks.
1 - 2 of 2 Posts
