Ok so I posted earlier about my fans not working. I started to do the diagnostic procedure for the car starting with the green test connector. Engine light was flashing and the fans were kicking so that meant that the fans were getting signal from the ecu. But not even 5 seconds after they were cycling I here a pop like a fuse failed the engine light stopped flashing and the fans stopped turning on and off. I disconnected the testing plug and put my car in the on position. The engine light failed to turn on in the on position.
What could have caused this to happen
And I also used electrical grease on the engine harness plug after I noticed some corrosion at the tip of the pins.
