i have 02 wrx
i have as follows,
GUTTED AIR BOX 4-1 header, with uppipe, 4inch to 3in bellmouth downpipe, apexi N1 cat back boost controller set at 14.8psi fully catless
I have a 2.5inch diameter flex pipe thats about 5 inches long this connects the downpipe to the cat back. i was told that since the apexi is designed to be used with the factory cat, its 2.5 inches itself, then it goes to 3inch later down the exhaust.
QUESTION IS ?>>>>> by me having a 2.5 inch flex section do you think i am losing POWER, is that big enough or do i need 3inch? would there be any hp increase by me cutting out that section of pipe and putting a 3inch flex section in place?
i have as follows,
