Oh ok, so advertised numbers are off from the factory? I thought maybe someone toyed with the ecu or boost before I got it.It's normal.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Yeah, I see it quite regularly going through gears in turns driving in the mountains. Quite impressive power gains I've noticedMy '16 will record spikes of up to mid-23 PSI fairly regularly. It occurs right as I shift when going hard thru the gears.
My dealer has a service tech that eats. drinks & breaths WRX's and said it was normal as a short "none load" condition.
No, it's a boost spike from questionable boost control strategy.Oh ok, so advertised numbers are off from the factory? I thought maybe someone toyed with the ecu or boost before I got it.
