Alright so I have a tial 38mm MVS EWG it came with all the included springs needed however it did not come with the spring I need a .9bar (13psi) spring. My tuner wants me to run a .9 bar spring so my question to you guys is can you use two springs to get to your desired spring pressure example .6bar black spring and .3bar green spring on a EWG I was reading another forum last night that said you could. It just didn't sound right to me to be using two or more springs to get the desired spring pressure any help is appreciated. Thanks..
