1 - 3 of 3 Posts
I have been having a problem with my Espelir springs since I purchased them. The back left tire is rubbing inside the wheel well when I turn. You can actually see a rub mark the wholeways around the wheel about 1-2 inch in from the outside diameter of the wheel. We even measured the gap between the back left and back right and it is off. Looking visually and by measuring with your hand you can even notice a difference. The coils on the back left end on the spring appears to be softer then the right in that you can see one less coil even though it is there. If anyone could help me out I would appreciate it. This car should not be this low with Espelirs.
Ryan
1 - 3 of 3 Posts
