Vendor
Whether you just need to replace your worn out brake pads or are looking for pads that outperform your stock parts, R1 Concepts has you covered. This is the leading manufacturer and retailer of award-winning automotive braking systems with one of the most comprehensive brake parts catalogs in the industry.
The company makes its replacement pads from the same materials as original parts and fine-tunes them to ensure they meet or exceed OEM specifications. They come with a special zinc plating designed to reduce corrosion, which leads to better appearance, long service life, and overall improved maintenance and replacement costs.
R1 Concepts™ | Automotive Brakes, Rotors, Calipers, Pads, Parts — CARiD.com
Reliable and durable R1 Concepts braking parts will get you to your destination safely no matter where you're going!
