1 - 3 of 3 Posts
Hello guys,
I recently blew my ej255 engine for my 2011 Subaru wrx and purchased a ej20 would I have to do any other modifications to make this work? Such as getting a new Ecu
Super Moderator
By engine do you mean long or short block? Also what EJ20?
EJ20E? 20D? 20k? 20g?
Or do you mean an EJ205? Or 207?
XJ pretty much covered it. What heads you are using will matter most, and there are a lot of different models of ej20 engines, and differences within those models. Some will work with less additional work than others.. some I wouldn't suggest using at all.
Whatever the case, you will need a tune minimum regardless of what engine it is.
1 - 3 of 3 Posts
