1 - 18 of 18 Posts
My 2010 Subaru Wrx shuts down when it’s warmed up and is very hard to start and keep running please help
Super Moderator
Any codes or anything? Have you done any diagnostics? Any strange or new sounds like knocking or whooshing?
Discussion Starter · #3 ·
Just says cylinders misfiring which I know is not because I had new plugs installed once it warms up shuts down
Super Moderator
You just had new plugs installed, was this because of the misfire, and dying at temp? What misfire codes do you have? It would be worth pulling the plugs and coils on those cylinders and doing a visual inspection. It also wouldn't surprise me if someone damaged a coil twisting and pulling it to remove it.
Discussion Starter · #6 ·
Installed A new turbo charger and new blow off valve Air cleaner new plugs new oil the oil filter Did all that when the turbo charger blew out have a stage 2 tune Nvidia exhaust Cobb intake Ran fine for a couple days then just started shutting off and miss firing
Super Moderator
I want to lean towards something in the ignition. When coils start to go bad the expansion from the engine heat can cause them to foul. What cylinders is it giving you the misfire for?
Super Moderator
Change the coils to different cylinders and see if the error follows the coilpacka
Discussion Starter · #16 ·
Ok sounds good I try that thanks get back to u when I give it a try
Camshaft position sensor ended up being bad causing all the problems so far so good fingers crossed lol thanks
1 - 18 of 18 Posts
