Hi,
I'm in the middle of replacing the uppipe on my 04. I litterally have every nut and bolt off and ready to go to lift the engine (I'm using a mix of the Perrin, Vinush and 04 service manual for instructions and guidelines) to drop the uppipe. But I'm stuck at getting the passenger side engine mount loose.
I know it's torqued on there pretty good, but I've been pulling on this thing for over an hour and no movement. I've sprayed it with Liquid Wrench before i started, but I'm exhausted now and have sprayed it again and will leave it till tomorrow now.
Question, am I going about loosening the bolt wrong? The actual nut is on the top side in the frame so it is a PITA to get at. Can i use the bolt head on the underside instead? or would i risk shearing the bolt head?
also, should it be humanly possible to get this thing off? (Not saying I'm a wimping but this thing isn't moving compared to everything else I've had to take off....)
thanks
Jared
thanks
Jared
