1 - 2 of 2 Posts
Is it worthwhile to replace the endlinks without replacing the rear sway bar? I want to improve my handling a little bit while I'm waiting for Eibach's sway bars to come out
Moderating on the run!
Not as worthwhile as upgrading your rear sway bar, unless you have a early 03 which came w/ a 20mm sway bar. If that's the case, then go for it- if not spring $80 for a new oem 20mm sway bar or a little more for an adj one.
Big Sky
1 - 2 of 2 Posts
