1 - 5 of 5 Posts
I am getting Eibach springs for my 2002 WRX. Do I need camber bolts or a wheel alignment?
You'll definitely need an alignment. You don't "need" camber bolts but you probably want them - they're only like $25. Do a search for more info.
What GV27 said...
If not for the camber bolts, I would have been stuck with close to -2 camber in the rear. With camber bolts, it's set at -1.0. Helps reduce some understeer.
$25-30.. just do it right.
camber/alignment bolts...
i just ordered a set of these today from boxer4racing.com seems they have some gold line canber bolts that work for -1.0 -2.0... hope this gets me back or close to stock.. i have been getting some bad tire wear.. about 8-10,000 miles on a set of tires...costing me way to much..
1 - 5 of 5 Posts
