1 - 4 of 4 Posts
I have searched and haven't found an answer....
When you install a threaded egt probe, do you need to use some kind of thread sealant or is the metal to metal contact enough to seal?
The reason I ask is, home plumbing fittings often have some kind of sealant between joints, as do the pneumatic fittings I have seen (i.e. teflon tape).
TIA
nope, its a compression style fitting. the tighter you go the more it seals ( to an extent). Just tighten it until its on there good, but not too much.
1 - 4 of 4 Posts
