Need Help... 7 CEl all at once
I was in my way from the bank after two weeks.. now I get a lot of crazy stuff on my car.. I pulled out the ecu codes.. and I get 7 codes.. and I can't delete tem.. here is the list..
When I turn the switch on, the CEL blinks 3 times ( this is due to the fact I'm using map 3 on my Utec) but then.. It starts to blink like crazy and the engine's fan, some of the relays, and A/C Fan goes on and off.. After I started the egine the CEL turn off and the fans turn off BUT.... it idles very rought.... goes from 1500 to -1900 back and forward also i see like steam camming out of my exhust.... WHat can this bee..?? here is a list of my mods..
Turbo XS Stage 4
vf30
sti injectors
Utec v.2
Code List..
P1518 Starter switch circuit low input
p1153- O2 sensor circuit range/performance (high) (bank 1 sensor 1)
p0851 ??
p1152
P0137 O2 Sensor Circuit Range/Performance Problem - Low Input (Bank 1 Sensor 2)
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
