3 questions is the emergency brake a different brake system than the pedal or is it just the rear wheels.
Also can a wrx flip if you are using the the e brake to slide or drift whatever the term is. Also I'm talking about 1st gear speed like up to 30 mph. I don't think is should fit if you are on an even surface. SO can some1 just clarify that.
Lastly the same as the 2nd question - what speed are safe to use the e brake to drift or do like a 180 (is there a certain speed that will just flip that car if you try something stupid like that) btw I don't plan on trying this ever just curious.
