I know the ecu of the 2002 wrx doesn't support dual avcs but would it be able to be run through an aftermarket engine management system or access port? Also if not, would it be necessary to swap the cam and cam gear with non avcs versions or would I be able to just remove and plug the avcs sensor in the heads?
