1 - 4 of 4 Posts
I am working on my driverside power window switch on my 2018 wrx and I removed all the cables from the connector and now I do not know where each single cable goes in the connector
Does anyone have a picture of it from a 2015+ wrx?
Little Homie
Google around for the factory service manual. It's out there.
I don't know why you are taking it apart but if it's to wire something into it, don't.
Discussion Starter · #3 ·
I took the car to body shop to get my door fixed. After it was done they said that my window was not working since I left the car there and it was not their fault.
Now I have to fix it myself.
I FOUND THE WIREDIAGRAM BUT I have 13 wires and in the diagram I cannot fond where all 13 go in the plug
Little Homie
The plug should be identified (D7) for example. You've got to find the pin out in the electrical section and use it. You'll have to identify some wires by description blue with white, red with brown, etc. Others you can use a multimeter and the ignition and switches.
1 - 4 of 4 Posts
