1 - 20 of 21 Posts
i have a couple hundred bucks to spend...Right now on my sti i removed the silencer box and i have a tanabe cat-back exhaust.
Im trying to decide between adding a downpipe or the just getting the k&n typhoon. Im sure the DP will add more HP, but im not a mechanic and i dont want a whole bunch of problems with my car either. What do you guys think i should get?
^^^what he said. when you need an intake you'll know
yeah i was kinda leaning that way, but being the fact that im far from a mechanic, I was a little concerned about throwing a CEL or boost creep.
if you have exhaust and add downpipe w/ STI you will boost creep.
I'm having the same dilemma right now.
I'm actually considering removing my exhaust and getting a down pipe, then adding the exhaust later when I can get my wastegate ported.
DOWNPIPE!!!
intake will make little to no difference!!! :thumbdown
Downpipe. Porting wastegate should be an easy job for a shop to do if you don't want to, same for downpipe. Though having put a downpipe in and had problems, I think you can do it...if I can, anyone can.
RN
Down pipe is for sure easy to install! All you need is a little common sense.
I don't think I would like to port the WG on the turbo. I have heard you need a bigger flapper...
Horsepowerfreaks quoted me 400$ to port the turbo & install a bigger flapper. Some people say you can do it without the bigger flapper but, you can REALLY mess things up if you go too big on the port.
Thats a big negative there ghostrider! I've got the TurboXS stealthback (High flow Cat), to the Stromung duel tip. And have 0, yes, 0, Boost Creep!
If you run Catless your going to for sure have Boost Creep.
My 2cents
DOWNPIPE - i am so far from being a mechanic its not even funny, but i installed it fine, just read every word of the install guide on this messageboard
Godspeed makes a good one.
Bigger flapper not needed when porting wastegate (side note).
RN
I vote for the Godspeed downpipe also. It fits fine and you get no CELs. I even passed PA emissions with it. The power is definitely there too (see sig).
I've heard rumors that the 05 does not creep as easily due to being a p18 housing now? Also I've heard different downpipes will yield different results...ie. a perrin dp with the divorced wastegate will not creep as easily as a bellmouth design. I have no experience with any of this..just hearsay...
1 - 20 of 21 Posts
