1 - 10 of 10 Posts
What is a better design for a down pipe.... im talking about the end that bolts to the turbo... I have seen some that are big open holes and I have seen some with a flat plate in front of the wastegate..
Here are some pics of what im talking about.
Flat plate in front of the wastegate
the flat plate has been said to add some turbulence and some case boost spikes but if your on a budget and dont plan on a turbo upgrade its fine.
bellmouth pipes are also higher quality pipes
if u want the best check out godspeed heard nothing but good:D
Nothing wrong with either of them. I have the invidia down, and stock gutted up. I'm lovin it.
KurleeDaddeeWRX said:
Whatever you do, get a uppipe that has a flex joint in it. It will save you headaches on uppipe leaks later.
if u use new gaskets and torque it using the vishnu instructions there will be no leak.
1 - 10 of 10 Posts
