1 - 8 of 8 Posts
ummm, yes and no ... high beams and low beams check ... if they check out the beam pattern then you FAIL!
Off course! you would pass the inspection!
Since all the bulbs on high/low beam and turn signal can light up and working properly, it can pass the inspection. And that's the point they are going to inspect!!!!
I have morrettes as well and i was told that since there 3 seprate bulbs (hard to explain) that they wouldnt pass the vis expection.??
Not sure about MA, but I know the inspectors in NJ check for the DOT wording on the Lights.. I know this from personal experience with JDM lights..
My .02 cents
ALex
My .02 cents
ALex
yeah they won't pass inspection in NJ if you don't have DOT on there
Evil imports works for nj inspection and they wouldn't even let him park his car on the property with them in because it 'set a bad example' for having illegal things on the car
1 - 8 of 8 Posts
