1 - 7 of 7 Posts
Getting the Eibach Prokit for a wagon ( Drops 1.3 front, 1.0 rear)
and I am wondering if the change in camber(with no other mods) will be helpful to handling or make it twitchy.
I cam currently running stock rubber and probably will continue to until they wear out and then I will likely go to 17's or 18's.
Is the camber bolt kit needed with this drop to get fender clearance or correct handling problems?
Moderating on the run!
The stock camber settings are -.25 front, -1.3 rear. The front is adjustable- to ~ -1.5, the rear is not adjustable. You may get a little additional neg camber in the rear from lowering, but likely not much. The front should be increased (negatively) to a minimum of -1.0 and ideally -1.5. This will help balance out the car some and increase your contact patch when turning- both good. You will see little (or no) extra wear at these settings. I think you should be fine w/o camber bolts. If you need more than -1.5 front or less/more camber in the rear then you will need camber bolts or plates.
Big Sky
Discussion Starter · #6 ·
Not to sound too ignorant but I take that those values are measurements of degrees and that any decent shop capable of doing alignments can acurately measure and set those values?
1 - 7 of 7 Posts
