1 - 6 of 6 Posts
im a retard when it comes to these things, but is there an easier way, or a DIY guide to removing and reattaching the foglights? im doing like a super cleaning of the entire car instead of paying 100+ dollars to get it detailed.
02 wrx.
Is in Love With the Admins Here
1. Remove any plastic pieces, bolts or screws that hold fog light assembly in.
2. Clean area you're concerned about.
3. Replace all plastic pieces, bolts or screws that you took out.
4. Reap the rewards of your hard work.
i have the tendency to break plastic locking peices and screws ... thanks for the info.
already snapped the lower driver's side snap pin from the front grille. :mad:
Super Moderator
You are in NJ? Plastic breaks more easily when colder - if you did not know.
1 - 6 of 6 Posts
