1 - 5 of 5 Posts
Got 145,143,142,142 in the 4 different cylinders. The cylinder numbers were 4,2,3,1 respectively.
I just read a post with instructions as to how to do a compression test and realized I didn't hold the throttle open when I did it. My motor has 22,500 miles on it and I've had the bigger turbo on it for at least about 5000 miles. I thought this motor was supposed to make 150 in all cylinders, but I have also heard that without the right piston rings, you will always get some blow by. Input anyone?
cut and paste directly from the service manual:
Compression (350 rpm and fully open throttle):
Standard;
951- 1,147kPa(9.7- 11.7kgf/cn?, 138-
166 psi)
Limit;
834 kPa (8.5 kgf/cd, 121 psi)
Difference between c linders;
49 kPa (0.5 k g f / c d 7 psi)
You are in good shape. Not only are all within spec, but they are nice and even between the four.
Jimbo
Jimbo
/\ what he said. Good numbers.
1 - 5 of 5 Posts
