Stock airbox unless you have an AP and can flash to the correct map
Wow that dealer has to be playing dumb trying to pin a CEL on a catback exhaust. You're getting a CEL because the WRX you bought was most likely traded in at that dealer with Cobb Stage 1 Tune Package and when the dealer replaced its ECM with a stock ECM the car was no longer running on the map for that intake. So you cobb intake is making you run lean on a stock tune. If the dealer is trying to solve the issue then 100% ask for a stock air intake to replace any stage 1 parts.Hello all, just joined the ranks of WRX owners! I picked up a 2015 WRX from a dealer that already had a few mods installed, but in order to insure the warranty stays intact, the car ECM was replaced with a new factory ECM by the dealer.
I can't be sure, but it appears the car has the Cobb Big SF CIA and perhaps the Cobb catback exhausted. Everything was working fine, but now I'm getting a CEL. The dealer ran the code and it is due to a lean fuel condition. They believe resetting the exhaust back to stock will stop the car from throwing the CEL, but from everything I'm reading, the lean condition is most likely from the CIA.
Would I be right in requesting the dealer reinstall a stock air intake so the lean condition will go away?
Thanks!
Thanks. Based on all the research I have been doing on the issue, this is the conclusion I had come to as well. I told the dealer this, but his "master" service tech said there should be no issue with the Cobb CIA. He thinks the issue is the O2 sensor in the exhaust. I even pointed out the warning on Cobb's site that states the car will require a map with this intake installed.Wow that dealer has to be playing dumb trying to pin a CEL on a catback exhaust. You're getting a CEL because the WRX you bought was most likely traded in at that dealer with Cobb Stage 1 Tune Package and when the dealer replaced its ECM with a stock ECM the car was no longer running on the map for that intake. So you cobb intake is making you run lean on a stock tune. If the dealer is trying to solve the issue then 100% ask for a stock air intake to replace any stage 1 parts.Hello all, just joined the ranks of WRX owners! I picked up a 2015 WRX from a dealer that already had a few mods installed, but in order to insure the warranty stays intact, the car ECM was replaced with a new factory ECM by the dealer.
Thanks!
Maybe avoid driving it if you can since its running lean.
