Delete
8210 Views 7 Replies 5 Participants Last post by  XJman
delete
1 - 8 of 8 Posts
The map specifies that it should be good for any 3" catted downpipe.
As XJ stated, you will be fine. At least you're thinking, lol, many do not.
So my paranoia that all catted downpipes are not created equal is just paranoia.
BUT, what about different CEL cats? Could a 200 CEL cat versus a 400 CEL cat lean out a vehicle due to flow? Or is it still such a negligible amount that the "one map fits all catted DP"?
  • Like
Reactions: 1
You should be alright regardless. There's also the HWG, LWG and normal maps for that tune. The count shouldn't make any difference. Many people run different downpipes with the Cobb tune without issue
You are correct in thinking that all catted downpipes are not quite created equal. However, they all use high flow cats and are all designed very similarly so they are VERY close in comparability. The difference between a Cobb, GrimmSpeed, Nameless, etc. will be negligible in regards to the ECU adjustments. The people who created Cobb's off the shelf tunes such as this "stage 2 MAP" we are speaking of, made them with the idea in mind that most people may not use their downpipe product. Since this tune is blanketed, it will be more conservative than a professional tune would be. Is Cobb's OTS tune best used with Cobb's high flow catted downpipe? Most likely, Yes. However, as XJ stated cobb's map notes say their tunes can be used with any 3" catted downpipe.
Thanks for putting my mind at ease. I will be shortly ready to do performance mods after I finish up suspension, and wanted to make sure I have a path of what to do/when to do it. Always have the end game in mind :)
Thank you.
They also offer different wastegate tunes to "fine tune" it to help meet boost targets and not overboosting.
1 - 8 of 8 Posts
