Status
Not open for further replies.
Administrator ...De Rerum Natura
DCCD - DRIVER CONTROLLED CENTER DIFFERENTIAL​
The planetary center differential in the WRX STi splits Engine torque in variable ratios between the front and rear wheels. It also gives the driver a choice - Leave ratio choice to the computer or set it yourself.
The driver can choose the value of the torque split between the front and rear wheels. Whether the driver makes adjustments to torque distribution in the manual mode via the console-mounted control wheel or entrusts distribution decisions to the DCCD control module through the automatic mode, the ratio of front/rear torque distribution can vary from 35 percent front/65 percent rear to 50 percent front/50 percent rear.
In automatic mode, DCCD varies torque according to input indicating acceleration, deceleration, cornering force and wheel slippage. In manual mode, the driver selects from six stages of center-differential lock-up. The more lock-up, the greater the torque directed to the front wheels – up to the 50 percent front/50 percent rear ratio. Mechanical limited-slip front and rear differentials enhance the system’s effectiveness.
The intent of the adjustable torque split is to improve handling and give the driver an increased sense of performance driving. DCCD accomplishes this through the integrated functions of numerous components.
The Parts:
Along with the mechanical components in the center differential, DCCD utilizes control units, sensors and switches from around the STi. Among them are the mode switch and control wheel on the console, throttle position sensor, parking brake switch, wheel speed sensors, ABS control unit, lateral G sensor with yaw rate sensor, rear differential oil temperature switch, brake light switch and instrument panel lights.
At the heart of it all, electronic control of a multi-plate transfer clutch in a center differential planetary gear set determines the torque split between the front and rear drive wheels. The split ranges from completely “free” (35/65 ratio) to “locked” (50/50 ratio). Clutch control is by an electromagnet. To lock the differentials, the clutch plates function to restrict torque to the rear axle, distributing more torque to the front. Lowering the torque restrictions frees up the ratio for more torque to the rear.
Fail-safe contingencies are built into the system. Should the electric coils that operate the clutch within the differential fail, power to operate the clutch turns off and the driver is alerted by a warning light. Sensor failure anywhere within the system fixes the last reading of that sensor as a default, and the driver is alerted that a fault has occurred.
Automatic mode:
Unless the STi is used for all-out off-road rallying and/or the driver is competition-competent, automatic mode is probably the best choice. The system utilizes sensor inputs that indicate driving style and changing road conditions. In automatic mode, DCCD reacts quicker with changes in front-to-rear torque ratio than most drivers are capable.
With the control wheel moved all the way forward, lock-up is 100 percent with torque distribution at 50 percent front/50 percent rear. The percentage of lock-up from the top “LOCK” stage to the bottom is:
  • 100 percent (50% front/50% rear)
  • 85 percent
  • 65 percent
  • 35 percent
  • 15 percent
  • 0 percent (35% front/65% rear)
Status
