1 - 6 of 6 Posts
Does the WRX have cruise control?? and how does a manual transmission car w/cruise control work??
yes it does, its on/off switch is near the door on the left side of the steering wheel along with the on/off switch for the fogs. its pretty much the same as an auto, it has a stick for lack of a better term to the right side of the steering wheel and behind it (similar location to winshield whiper controls) press on, push the rod up at desired speed, and your crusiing. push the rod down and you slow down, brakeing or changing gears turns it off, not much different then any other car
lil tip... i learned that u cannot set it above 90mph... could have made my trip that much faster... :D
-mike
using the arm on the steering wheel you can click it once to accelerate or slow down by 1 mile per hour. I find it useful to stop my speeding habits on roads where cops frequent.
Thinking Man's Engine
works just like the automatic...and the clutch pedal cancels the setting also.
Basically only use cruise control on long flat roads/freeways. You switch it off when there are hilly sections that would require you to drop down gears.
1 - 6 of 6 Posts
