Hello, this is literally my first post and I hope I'm doing it in the right place. I bought a used 2011 base model WRX a few months ago and I've been loving it. Last week the CEL lit up immediately after a fill up so I got my scanner to scan it. The code was P0137 which indicates an issue with the rear O2 sensor. I ordered a replacement sensor and planned to replace it. Since then the CEL went off so I procrastinated the repair. The light came on again (same code), again after a fill up. Since then the turned off again.
My question is this. If the O2 sensor is bad wouldn't the CEL stay on? or at least every time I started the engine? Also, why is there such a strong correlation between fill ups and the light coming on? I don't want to replace the sensor if that's not the issue. Has anyone had a similar experience, or know what the issue may be.
By the way I did replace the gas cap already thinking that may have been the issue. I have also inspected the wiring harness to the best of my knowledge, which is VERY limited.
Thanks guys and gals.
