1 - 2 of 2 Posts
Hi guys
I having trouble finding a hose that I need for a radiator upgrade.
For some reason I cant insert a pic so ive linked the website that gives a diagram of the part im looking for. Its number 11 on the diagram.
Does anyone know what this part is called ????
2002 SUBARU IMPREZA WRX Lower Radiator Coolant Hose
I just bought a mishimoto radiator that should fit directly in, however it has a radiator cap mounted onto it directly where as the stock radiator didn't.I believe this is standard for the 2002 STI. The pipe I require has a T connector at the end rather than straight through as showen in the picture. I have a 2002 WRX, Chassis GDA, engine EJ205
new radiator ; Subaru Impreza WRX and STI Performance Aluminum Radiator, 2001-2007, by Mishimoto
Please help
People typically just use a T-fitting and connect the overflow from the "new" rad cap on the rad to the existing overflow. There is no pressure there, it's overflow, so you can use a T-fitting and two pieces of hose to solve your problem.
1 - 2 of 2 Posts
