121 - 140 of 583 Posts
My Insanity...
Engine/Drivetrain:
Custom Bolt-on Turbo: Garrett gt30r-15 chra, AVO .84 turbine housing, T04b Compressor housing
JDM V7 EJ207 ShortBlock
JDM STI V8 Intake (1 piece, no TGV)
JDM STI V7 heads with JDM STI V8 Cams
JDM STI V7 wiring harness and ECU (AVCS enabled)
Ultimate Racing Uppipe
Tial 38mm External Wastegate
XS Engineering 800cc Injectors
Fujitsubo Equal Length Header
Stock STI Cat back
APS D/R 500 Frount Mount Intercooler
APS DR Series FRP/01 Race Fuel System
TurboXS Australian spec UTEC
TurboXS Short Ram Intake
HKS Downpipe
Forge BOV
Walbro 255lph Fuel Pump
STi Group N Motor Mounts
JLMotorsports Pitch Mount
Perrin Turbo Inlet Hose with Custom silicon extension
Port and Polished Throttle body
NGK BRK8EIX Iridium 2 step colder spark plugs
Drivetrain/Suspension/Braking:
STI V6 RA Gearset w/new bearings and Synchros
Exedy Twin Semi-Carbon Clutch
STi Group N Transmission Mount
TWR Racing 310mm Front Brakes
AST Sportline I Coilovers
Poltec Titanium Lateral Links
Progress Front Sway Bar
Progress Rear Sway Bar w/Heavy Duty Mounts
Poltec SS Swaybar Endlinks w/mount box
H6 Rear Caliper Relocation Bracket
Carbotech H6 Slotted Rear Rotor
Carbotech Bobcat Front/Rear Pads
Whiteline Anti-Lift Kit
Noltec Steering Rack Bushings
Goodridge Stainless Steel Braided Brake Lines
Dunlop Wintersport M3 205/55/16 (Winter)
Falken GRB FK451 215/45/17 (Summer)
GTSpec Front/Rear Strut Tower Bars
Interior/Exterior Dress-Up:
USDM V8 STI Front Seats
JDM STI V8 Rear Seat with pass-through
STi V7 RA Limited Wing
STi V7 Front Grill w/ Pink I Badge and STI Logo
STi V7 Hoodscoop
STi V7 Projector Headlamps (currently off the car!)
Bohmen/McCulloch 5300k HID w/ Direct Power Wire Harness
Debadged 'Subaru'
Blitz DTT
TurboXS Tuner Pro
Defi Pod w/Defi EGT, Boost, & Oil Pressure Gauges
Other/Miscellaneous:
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
GPMoto Mechanical Cel fix
EJ207 with XS450 Dyno
XS450 Dyno Thread
PE1820 Dyno Thread
Pics Thread
2002 Silver, 5-spd Sedan, purchased 11/03 with the following mods:
APS TMIC
APS cold air intake w/ K&N filter
APS turbo back exhaust
APS unichip
STI hood scoop
Eibach springs
Cobb CT-One wheels (black)
Sumitomo HTR Z II tires
Prodrive shift knob
Autometer Boost guage
Since Purchase:
PIAA Superwhites
PIAA Ion Crystals
Fog light mod
Grounding mod
Debadged SUBARU
Pink 'i' badge
Tinted
Optima Red Top
Pics
Engine:
Perrin Short-Ram Intake
Forge BOV
Autospeed up-pipe (ceramic coated)
APS trubo-back exhaust (ceramic coated)
Forced Performance 18g
Hyperflow V2 FMIC
STI RA Spec C TGV housings (ceramic coated)
Perrin Fuel Rails
STI Injectors
Walboro fuel pump
TXS UTEC
Apexi AVCR
Autospeed crank pulley
STI engine and pitch mounts
Zerosports radiator cap
Samco silicon radiator hoses
Samco silicon turbo inlet hose
Suspention/Brakes:
Perrin springs
AGX struts
Perrin sway bars (front/rear)
Perrin rear end-links
Cusco front lower brace
STI replica strut braces (front/rear)
DBA Gold Rotors (front/rear)
Hawk HPS pads (font)
Goodrige SS lines (front/rear)
Motul brake fluid
17x7.5 SSR Competitions
Bridgestone Potenza S-03s
Transmission:
Exedy lightened flywheel
Exedy organic street clutch
STI transmission mount
STI short shifter
Royal Purple
Exterior:
OE sideskirts and rear
Morettes with Phillips HIDs
Carbon Fiber hood
"Jaguar style" tail lights
STI replica solid fog light covers
Interior/Entertainment:
Greddy EGT, Boost and Oil Pressure gauges
Pioneer DEH-P6500
Crossfire 404 (400x4)
Crossfire 401 (400x1)
12" Polk/Momo sub
6 1/2" Infinity Refrence components
4" Infinit refrence coaxials
5 1/2" Kenwood Dual Mags
Momo shift knob/boot
Autospeed shifter trim
Autospeed dead pedal
here it goes....
Engine:
Utec
Turbo xs Top mount intercooler v2
Ultimate racing 600cc injectors
paulrex tuned
Hks catback
Helix down/midpipe
Gruppe-s up pipe
1 step colder plugs
5w30 synthetic
Suspension/Brakes:
Eibach springs
Rota Actions
Sti 4 pot front brakes w/stainless lines
turbo legacy vented rear brakes
Transmission:
Kartboy short shifter and bushings
Exterior:
rep sti front grill
2004 sti side skirts
CF blinker covers
cleared headlights
blue bulbs
OE rear fully painted
STI V1 front lip CF
8000k Hids
STI hoodscoop
2004 Sti rear spoiler
de-subaru'd
2004 sti front and rear seats (USDM)
2004 sti door panels
Greddy turbo timer
V1
alot of alarm stuff
utec remote switch
sub
de-4th brake light
Re: 2002 silver WRX sedan
virpacalis said:
Valentine 1 w/remote display
Autometer bezel pod
VDO Vision Series 52 mm egt (°F) & boost (0-30 psi) gauges
17x7.5 SSR's (offset 50mm)
Pole Position S-03's/Blizzak LM-22's
Eibach Pro-Kit
Eibach alignment kit (camber bolts)
STi aluminum control arms
Freedom Design front strut brace
Cusco 40mm rear strut brace
SPO front (22) & rear (22-24) sway bars
TWR bbk: red 4-piston front (2.1kg w/o pads, 3.05kg w/pads)/2-piston rear calipers
332x28mm (8kg) front/320x24mm rear 2-piece slotted rotors
forged aluminum hats, calipers, and caliper pistons
stainless steel brake lines
Subaru rear differential protector
Subaru short throw shifter
Cobb shifter bushings
STi engine & transmission mounts
ACT (organic) street clutch (from Cobb)
Exedy 13.5 flywheel (from Cobb)
RA gears (Rallispec)
GReddy oil catch can
Kartboy hangers
Vishnu power pulley
Vishnu 321 uppipe
NGK platinum plugs (BKR7EVX11)
STi 565cc injectors
342 Walbro fuel pump
APS SR30 turbo
APS fmic (black)
APS 3" tb (1 cat)
APS cai
APS dual-vent bov
Perrin turbo inlet hose
Ecutek dynotuned by Shiv
dyno graph (low number is for my valet map)
Cobb 420 cel fix
EGT cel resistor
in-dash black mask for CEL (electrical tape on the inside of the gauge assembly hiding misfires)
Delta Dash (to see how things are working espcially for codes other than the stupid misfires)
cf STi GT wing (Gruppe-S replica)
35% tint: 5 windows + eyebrow by Leeberbs (NJ)
painted skirts and fog light covers
2003 Aspen White
Engine
Intake silencer removed
HKS SSQV
K&N drop in
Grounding mod
Utec
Custom TEC 18G
STI 565 cc injectors "pinkies"
Walboro 255 lph fuel pump
PDE uppipe
M2 Performance turboback w/ 1 high flo kitty
Interior
Diamond plated aluminum floor mats
Eclipse 8022 DVD/CD/CDRW/MP3 combo
JL audio 12W3
JBL 500X1
MTX 200X4
Gamecube installed
Speedhut white indiglow overlays
A-pillar gauge pods
autometer boost gauge/EGT speedhut oil pressure gauge
blue LEDs in HVAC and ignition illumination
Interior custom painted blue
Lots of DIY wiring mods
momo air leather shift knob
sti shifter trim
momo racing shift boot
Apexi full auto turbo timer
Remote Map Selector Switch
Exterior
mesh fog light covers
clear side markers
Factory white sideskirts
Genome V2 Grill
morette front head lights
Brightstar HID kit
Subaru removed and WRX moved to cover assenine shortline holes
Window tint 20%
blue engine hose dress up kit
Optima Red top
Rota Tarmacs
Greddy oil catch can
Handling
Whiteline lowering springs
Cusco front strut tower brace
Cusco rear strut tower brace
Cusco Ver I under control arm brace
Falken Azenis
Cusco adjustable rear sway bar
Miscellaneous
s/s brake lines
Cobb double adjustable short shifter
Cobb reinforced tranny mount
Soon to be installed
Vishnu lightened pulley
2002 World Rally Blue Pearl Impreza WRX
5 speed MT Sedan
Performance Mods:
2.5 L. STI Shortblock
TurboXS UTEC
TurboXS High Performance MBC set at 17.5 psi
KMD Manifold/Header
TurboXS Down-Pipe
TurboXS Mid-Pipe w/Cat
TurboXS Catless Mid-Pipe (race days)
TurboXS Rear-Pipe
TurboXS Magnaflow Muffler (off for race days)
TurboXS Top Mount Intercooler
IHI VF30 Turbocharger
STi 550cc Injectors
Walbro 255lph Fuel Pump (#342)
K&N Typhoon Air Intake System (CAI installation)
ATR Up-Pipe
Samco InterCooler Hoses
GFB Pulley Kit
Exedy Sport/Performance Clutch Kit
STI Group N Tranny mount
STI Group N engine mounts
NGK BKR7E plugs
Grounding/Earthing mod
STI short shifter with STI Titanium Shift Knob (factory)
OEM Boost Gauge (factory)
NOS Nitrous Wet Kit (not presently installed)
Cosmetic Mods:
Morette Headlights
STI Hood Scoop
STi Mesh Foglight Covers
Rear wing Spoiler (factory)
Removed Sideskirts
Painted Brake Calipers Red
Painted Rims Gold
From the Factory Extras:
Premium Sound Package
Auto-Dimming Mirror & Compass
Arm Rest Extension
Upgraded Security System
Underseat Sub-Woofer
Interior Air Filtration Kit
Other:
Delta Dash
AP-22 Performance Meter
Bel Vector 95 Radar Detector
Coming Soon:
Tinted Windows
MIL Eliminator (keeps check engine light OFF)
284 hp at the wheels on 9/20/02 at TurboXS on pump gas at 17.5 psi boost with one cat and muffler in place.
Add a shot off N2O and I'm at 367 hp at the wheels!
That's approximately 460 hp at the crank.
Above performance data on 2 L. motor. No stats yet at 2.5 L. :)
Carlo
performance-
hks carbon-ti cat back
bosal dp
txs up pipe
boost monkey mbc set at 15.5-16.0
turboxs rfl bov
snorkel hack
looks-
jun eyelids
clear side markers
soon to come-
utec
vf 22
pe650 injectors
walbro 255
hks cams
borla header
transmission soon to come-
valve body
hayden trans cooler
3800 stall t.c.
best time at track 13.8sec at 97mph
best g tech 13.3sec at 101mph most likely wrong but avarage is 13.7 still damn good for a stock turbo 4eat
02 WRB Sedan 5sp. 275.96whp/264.60wtq on a dynojet dyno.
Performance:
U-chip(TXS base map st.4 + TMI)
TXS V.1 TMI
AutoSpeed flex uppipe
TXS TBE catless w/RFL
STi injectors
Walbro pump
Samco I/C hoses
VF30 Turbo
TXS shorty intake and silencer removed airbox(I switch back and forth)
MIL's front and rear/ Perrin rear active mil.
Graham Goode BOV(100% atmos./ not on car)
GTSpec radiator shroud
Suspension:
Cusco Zero2R coilovers with 7/5 springs
Cusco V.2 Lower arm bar
Cusco rear strut bar(OS)
Whiteline ALK(comfort)
Whiteline "Taller" front strut tower bar
Hotchkis F/R 1" hollow swaybars
Hotchkis rear endlinks
04 RSB mounts(I have 02)
Driveline Mounts:
Cusco Motor/tranny mounts
KB shifter bushings
Interior:
Full leather
Factory boost gauge
Pivot built-in turbo timer(toggle switch)
Exterior: WRB
Morettes in half paint(raccoon eyes)
STi mesh fog covers
STi scoop
STi splitter
Factory wing
Blue mirror tint on all rear windows
Wheels/Tires:
17" Rota subzero's
225-45-17 Falken Azenis(comp)
Dunlop wintersport M3's on stock rims
My drool list:
Cusco "Tarmac" center diff and 1.5 front diff.(35/65 split ratio)
RA or KAAZ gearset
Better engine management
7pt. cage
By this time I'll need a new engine:tongue:
Cheers
-Bought the car new in 10/01 stock w/ security upgrade,speaker/sub upgrade blah blah..
My Ride
2006 Metal Gray STI
Performance:
K&N Drop in
Accessport Stage II 91
Ceramic Coated Cobb Downpipe w/cat
Greddy EVO 2 Catback
DBA Slotted Rotors/Hawk HPS Pads
Other Stuff:
STI License plate holder (good for 10 whp)
Lead Foot
okay my car is the way i like it ill post a pic and giv u da spekz
~Intake~ and Exhaust PROF VRS CS cat back exhaust system XSpeed front pipe GENIE 3" hi-flow catalytic converter BLITZ SUS air filter AVO carbon air box AVO silicon turbo intake pipe GMS oil catch tank ~Turbo and Intercooler~ BLITZ blow off valve dual drive HKS intercooler kit STI IHI VF22 ball bearing turbo ~Electronics~ BLITZ SSBC boost controller ~Engine~ Earls braided lines SRR silicon hoses ~Suspension and Brakes~ JIC N1 suspension kit STI 4-pot brake calipers conversion Project U Comp B 0-600°C brake pads (FR) Endless NA-S Brake Pads (RR) SAFC slotted disc brakes (FR) ~Transmission~ EXEDY Racing brass button clutch ~Accessories~ C-West original full body kit GT touring spoiler STI Type-RA clear tail lights BLITZ MSTT turbo timer BLITZ electronic din panel BLITZ power meter ID BLITZ DC Racing meter boost 60mm BLITZ DC Racing meter oil pressure 60mm BLITZ Racing exhaust temperature meter 43mm
and all that means is that my car pumps out a grunty 482BHP and a good-ass 1/4 mile time of 11.92 on street rubber:rolleyes: :wiggles:
2003 silver WRX
Performance:
-Turbo XS down pipe
-Turbo XS mid pipe [high flow cat]
-Turbo XS UTEC
-Turbo XS ABC
-Perrin front mount intercooler
-Perrin short ram intake
-Perrin lightened pulley
-Perrin catch can converted to coolant overflow
-Perrin Fuel Rail
-Perrin radiator shroud
-IHI VF-34 ball bearing turbo
-STI 550cc high impedance injectors
-Walbro 255lph fuel pump
-Gruppe-S up pipe
-Blitz NUR SPEC axle back
-Denso one step colder spark plugs [ik-22]
Exterior:
-SOA front lip
-SOA rear lip
-SOA side skirts
-SOA side strakes
-SOA solid fog light covers
-STI hood scoop
-JDM STI black chrome headlight w/hid
-Full de-badge
-22% window tint
-stone guard paint protection
-Smoked side markers
Interior:
-Sparco torino front seats
-Custom upholstered rear seat to match front
-Custom door panels
-MOMO shift knob
-Custom shift light
-SOA modified gauge pod to hold 3 52mm omori gauges
-Apex’i turbo timer
-Kartboy short shift kit
Stereo:
-Pioneer head unit
-MTX amp
-MTX Sub
-Kenwood Sirius satellite radio
Suspension:
-Progress springs
-Perrin rear sway bar [22mm adjustable]
-Cusco front sub-frame
Wheels/Tires:
-Advan RG 18x7.5 [gold]
-Yokohama ES100 225x40x18
Time for an updated list.
'02 WRB wagon
TXS Stealthback
gutted stock uppipe
gutted stock muffler
Sedan rear swaybar
Whiteline solid endlinks
STI motor and tranny mounts
Kartboy shifter bushing
Subie short throw shifter
Momo Raptor shift knob
Goodridge brakelines
ATE Super Blue brake fluid
Redline in tranny and rear diff
Autometer boost gauge
HKS turbo timer
STI hoodscoop
K&N air flilter
painted headlight mod
CF front corners
Debadged and tinted
Summer wheels:
Rota Actions in Gold
Yokohama AVS es100's
Winter wheels:
Stock WRX 16's
Dunlop M3 Wintersports
I also have a Cobb AccessPort tuner on order
My car is pretty lightly modded, but I need high reliability. It sure is fun to drive!
PSM 2002 wagon
EJ257 block
CP pistons, .5mm oversize
Crower 264 cams
Crower valvetrain w/ ti retainers
Crower valves
Cosworth bearings
Cosworth timing belt guide
Cosworth head studs
Cometic head gasket
Deadbolt 'Zilla TD06H-20G turbo, clipped
ECU Flash reflash
CoolingMist methanol injection
PE 800cc injectors
Hyperflow TMIC
Ultimate Racing EWG uppipe
Tial 38mm wastegate
APEXi AVC-R boost controller
Bosal downpipe w/o wastegate tube
QTP exhaust cutout w/ controller
Maddad 3rd cat eliminator pipe
Borla Hush catback
P&P stock exhaust manifold
Perrin fuel rails
Perrin BigMAF intake
Perrin radiator hose
Walbro 255 fuel pump
Blitz DD BOV
Blitz oil cap
Samco ancillary hoses
STi Group N engine mounts
STi Group N pitch mount
TGV deletes
DIY grounding kit
PPG synchro gears, 1-2 straight cut / 3-4 helical
RPS StreetMax clutch
ACT Streetlite flywheel
STi Group N transmission mount
STi braided clutch line
KB shortshifter/bushings
Whiteline rear differential bushings
Eibach Pro-Kit springs
KYB AGX struts
Whiteline adjustable rear sway bar
Whiteline rear strut tower brace
KB endlinks
Hawk HPS Brake Pads
Techna-Fit stainless brake lines
Rota SDR 17" rims, silver
Falken FK-451s (summer)
Nokian WRs (winter)
STi v.7 hood scoop
STi v.7 IC splitter
STi mesh fog light covers
Liberal replica grill / JDM "I" badge
STi gas cap
OEM painted sideskirts
Prodrive stone-guards
clear side blinkers
cleared headlights
35% tint
Escort 8500 radar detector (hardwired)
Omori boost, EGT gauges
Momo Race shift knob
STi shifter trim
JL 12W6v2 subwoofer
MTX 150X2 bridged
MB Quart PSD 213 5.25" component front, 4" rear
Kenwood 100-watt per-channel amp front, 60-watt per-channel rear
2002 WRX
WRB
4EAT transmission
Old setup included: uppipe, downpipe & catback, Ecutek reflash
power mods:
Perrin Uppipe
Invidia catback
APS downpipe without cat
APS SR30 turbo
PE 650 injectors
Walbro 255l fuel pump
APS Fuel Rails
APS DR500 Front Mount Intercooler (black)
APS Dual Vent Blow off Valve
APS short ram intake
Custom ECUtek tune/dyno tune: 248whp and 204lb/ft torque
other:
Autometer triple gauge pod
Greddy boost gauge
Greddy EGT gauge
Greddy Oil pressure gauge
2003 WRX Sedan
Sedona Red Pearl, purchased July '03
Factory:
5MT
Rear Spoiler
Auto-dimming Compass Mirror
Cabin Air Filtration
WRX Carpeted Floormats
Armrest Extension
Upgraded Soundsystem
Security system/keyless entry
Engine & Performance:
K&N Drop-in filter
GP Moto Intake Elbow
TurboXS TBE (DP Thermo Tec wrapped and Hi-Heat Spray coated)
Crucial Racing Uppipe
Crucial Racing Coolstat 71 deg. C T-Stat
APS Twin-Vent BOV
SpeedMonkee Zero-Loss Ground Kit
SpeedMonkee Heatshield
STi TMIC (USDM)
GTSpec STI Splitter
STi Group N mounts (Trans, Engine, Pitch Stop)
Buddy Club Billet Oil Cap
Optima Red Top Battery
Greddy Oil Catch Can
Vishnu Xede Stage 1
IHI VF23 Turbo by Deadbolt Speed P&P, Ceramic coated
Walbro 255lph FP
GFB Pulley Kit
Future mods - injectors, Stage 2 Xede flash and re-tuned by [email protected]
Handling & Braking:
Volk Racing LE37-T 17x7.5 Gunmetal w/Rays Lugs
Bridgestone Potenza S-03 225/45-17 tires
Toyo T1-S 225/45-17 Tires (4 sale used)
Tein RA Coil-overs
Whiteline Anti-lift Kit (Race)
Whiteline Rear Camber bolts
Whiteline Urethane Steering Rack bushings
Whiteline Rear Diff Lock-out bolts
Cusco Rear Sway Bar
Helix Rear End-links
STi Titanium Front Strut Bar (JDM)
STi Lower Ladder Bar
Cusco CF Rear Strut Bar
Perrin/Wilwood Brake Kit (4P F & 2P R) DBA Slotted F Rotors
SS Brake lines
Exterior, Interior & Misc:
STi LHD (EDM) Projector Headlamps w/H1 Acumen 8000k HID kit
STi Mesh Fog Light Covers (painted SRP)
STi Hood Scoop
STi Trunk badge
STi Shifter Console (JDM)
STi Key
ClubWRX.net Keychain
Painted OEM Side Skirts
Rear windows tinted
De-badged SUBARU
Momo/Subaru Race Air Leather/Aluminum Shift Knob
Aluminum Dead Pedal
Kartboy Exhaust Hangers (long)
Kartboy Shifter Bushing
OEM Top Mount DIN Housing
Omori 45mm Boost, Oil Press., Exh. Temp
Sensoro Silver Bullet Radar Detector
Actron OBDII Reader
Beltronics Vector FX2
NeO-Synthetic 5w-30 Turbo Oil
NeO-Synthetic 75w-90 Gear Oil
Dyno results:
Baseline Dynoed at ATP (4/16/04) in Fremont, CA at 210HP 208TQ [Xede Stage 1, stock uppipe, stock turbo, TXS TBE (not wrapped), STI intercooler - no air flowing]
Dynoed and Tuned at Vishnu (5/24/04) in Pleasanton, CA at 251 whp [after VF23 install, using stock fuel pump and injectors]
Dynoed at ATP Turbo, Fremont, CA (5/29/04) @ 268 whp/261 wtq
2004 WRX Sedan
World Rally Blue
Factory:
5MT
Armrest extension
Appearance:
Gold 17x7" ADR Flite 5 Wheels wrapped in..
Hankook Ventus K102
Genuine STi wing
Cleared headlights
20% window tint
Momo door sills
Billet aluminum shift knob
Painted sideskirts
STi front corner splitters
V-Limited carbon fiber replica lip
Performance:
Catless Up Pipe
Catless Mid Pipe
Bosal Down Pipe
Injen Super SES Catback
Intercooler Sprayer
HKS Type 0 Turbo Timer
Manual Boost Controller @ 16psi
K&N Drop Air Filter
Samco Silicone Intercooler Hoses
8 Gauge Grounding Kit
Redline Shockproof Heavy Gear Oil (DO IT!!)
Handling/Braking:
Tein SS Coilovers w/Strut tops
Cusco Front and Rear Swaybars w/Custom Endlinks
Cusco 4 Point Subframe Brace
Carbotech Bobkat Brake Pads
Goodridge SS Brakelines
Interior:
Kartboy Shift Bushings
Kenwood MP3 Player
Custom Brushed Aluminum Center Gauge Pod w/
EGT
Boost
Oil Pressure (w/Greddy sandwich adapter)
Genuine STi gauge cluster
Momo Door Sills
...all bought for less than retail prices, except tires.
03 Aspen White WRX
297whp 273wtq
Dyno #'s are from 2 1/2 yrs ago. Same turbo and front mount, diffrent everything else.
Engine mods:
APS DR500 FMIC Piping (Jet Hot Coated Platnium)
S-Max Intercooler
S-Max BOV
STI V7 Intake Manifold (Jet Hot Coated Platnium)
VF30
STI injectors
Walbro fuel pump
Helix V2 downpipe
GTSpec GenII manifold
GTSpec uppipe
Gramlights 57 Dragon Exhaust
Greddy Airnx Intake
Greddy Profec B Type S
Greddy catch can
Greddy turbo timer
Greddy fuse box cover
Greddy Radiator Reservoir
Ignited batt. kill switch w/ removable key
Kazama Voltage stabilizer
DEI Cry02 IC sprayer kit
DEI Purge kit
DEI Fuel chiller bar
DEI bottles(2)
DEI 3" intake chiller pipe
BDL Industries Fuel rail kit
BDL Industries Fuel filter
BDL Industries crank pulley
BDL Industries throttle body spacer
NX EFI Wet kit
Venovus NCM-2 Nitrous Control Module
Venovus VRM-1 Nitrous Solenoid Driver
Samco MAF hose black
Samco radiator hoses black
Agency Power Inlet pipe
Beatrush Radiator shroud
Beatrush pulley cover
Beatrush oil cap
Beatrush motor mounts
Beatrush Alt Pulley
Greddy Radiator cap
Q-Concepts Brake cap
Q-Concepts clutch cap
Q-Concepts Power Steering cap
Forge Power steering reservior
Speedmonkey Rad. overflow tank
Kartboy exhaust hangers
Optima Battery Relocated to trunk
Ignited batt. kill switch w/removable key
TurboXS Utec w/ Remote Map switch
Drivetrain/Brakes:
STI RA Gearset
Beatrush tranny mount
Beatrush Pitch mount
Beatrush shifter bushings
Beatrush rear diff. bracket
Fidanza Stg3 clutch
Fidanza Aluminum Flywheel
Fidanza short shifter kit
Redline tranny fluid
Wilwood 6 Piston Fr BBK
Wilwood 4 Piston Rr BBK
Wilwood braided lines Fr/Rr
Wilwood race pads Fr/Rr
Motul brake fluid
Suspension/Wheels:
GTSpec Front stb
GTSpec rear stb
GTSpec trunk cage
Cusco Rr camber plates
Cusco Rr swaybar
Cusco Rr endlinks
Beatrush Lateral links
Beatrush subframe brace
H&R coilovers
STI Fr strut tops
Rays black lugs
18"x8" SSR SP1 (Proffesor)
Dunlop Direzza 235/40-18
Exterior:
STI V2 front lip
C-West sideskirts
C-West rear lip
Aqua Reverse hoodscoop
Prodrive P1 WRC grill
JDM STI headlights
JDM clear fender lights
Ignited 8000K HID kit
PIAA 9005 high beam
PIAA 1156 parking/blinker
PIAA Silicone windsheld wipers
06 STI rear window vain with GTSpec CF center peice
Tein Hood Dampners
Trunk debadged/key hole shaved
WRX license plate trim Fr
Interior:
USDM STI V8 cluster
Full V8 Interior
Greddy Intelligent Infometer
S203 Red Hazard Button
Cusco 7-Point Roll Cage
Beatrush rear seat delete
Autometer Nexus Boost
Autometer Nexus EGT
Autometer Nexus Oil Press.
Autometer Nexus Nitrous Press.
Autometer Nexus control unit
Autometer Nexus Wideband A/F
Autometer Digital Shift System
Autometer cluster bezel
ATI steering column pod
Subiegal pillar pod
Ignited push button start
Ignited Nitrous purge button
Ignited CF toggle switches(3)
NRG short hub
NRG quick release
MOMO Monte Carlo steering wheel
Armrest Extension
Project MU shifknob
Project MU Pedals
STI floor mats
ICE:
Pioneer AVIC-D3 headunit
Pioneer I-Pod interface
Apple I-Pod Nano
MMats SQ4070 amplifier
MMats 6.5" Pro seperates Fr
MMats 6.5" Pro coax Rr
Stinger 1 Farad Capacitor
2004 WRX Sedan, my Blue Baby
PERFORMANCE:
Perrin Up-pipe
Borla Hush Catback
Resonator-ectomey
STI Group N Tranny Mount
COBB AccessPort
Perrin short shift adapter
Perrin Rear Adjustable Sway Bar
Whiteline Endlinks
Continental ContExtreme Contact 225/50/16
INTERIOR:
Autometer Carbon Fiber Boost Gauge
Autometer Black Moutning Cup (on steering column)
Pioneer Deck
Alpine Component Speakers (front)
Infinity Speakers (rear)
JL Audio 12 inch sub
JBL 150 watt amp
Momo all-leather shift knob
SOON TO COME......(in no particular order)
-Stoptech Stage 1 Brake Kit
-COBB Catless Downpipe
-Bigger TMIC
-STI Engine Mounts
2003 Platinum Silver Wagon
5MT Born November 17th, 2002
Engine:
Silencer removed
Fiberglassed intake elbow connection
Grounding mod
Greddy Catch Can
Samco intercooler Hoses
Perrin lightweight pulley
Turbo XS stealth turbo back
Prodrive Muffler
Helix Uppipe
COBB AccessPort
Custom Intercooler Spray
Walbro Fuel Pump
VF34 (soon)
STi Injectors (soon)
Exterior & Handling:
17" Rota Tarmac II Steel Grey
Kumho Exsta MX
Eibach Pro Kit Springs
Rear camber bolts
Helix endlinks
STi Sideskirts
Mesh fog covers
Roof rails removed
Badges removed
27% Tint
Hood Scoop/Radiator screen
Custom painted OEM rims
Blue "I" badge
Black headlight mod
Silvania Whitestar bulbs
LED Parking Lights
Foglight "on" mod
Disabled DR Lights
MRT Replica STi Scoop
Primitive Racing Rear Diff Protector
Primitive Racing Front Skid Plate
Interior:
Passport 8500
Smart Cord
Blitz Dual TT
Greddy Oil Pressure
Greddy EGT
Greddy Oil Temp
Greddy Boost Gauge
Odyssey Outside Air Temp Gauge (dakotadigital.com)
Autometer Triple Dash Gauge pod
Autometer Instrument Gauge Bezel
Clock relocated to headliner
Ice:
JBL 300x2
2 10" JL W0
Custom Fiberglass Enclosures
Alpine HU (soon)
