1 - 5 of 5 Posts
I replaced the stock lights with the color changing LED lights, and I put the signal blinker module in. The problem I'm having is that my right light works when I put the flasher on but it doesn't work when I do it on the left side.
Does anyone know what the problem could be?
Yes, same thing happened to me. Just switch the light bulb. You put the one that goes on the left side on the right and vice verse.
I just tried switching them but the left turn signal still doesn't work. When I turn on the headlights they both light up. The left turn signal doesn't even work in the car. The little arrow you can see in your dash doesn't work when I put the blinker on or the emergencies.
maybe a bad module or something...
1 - 5 of 5 Posts
